HLram
- Dec 22, 2012
- 1,174
- 229
- Texas
- 2012 and 2007
- Hemi 5.7 in both
This is a post I have in the 3rd Gen section that has not gotten any responses. Can one or some of you 4th Gen guys that used to have a 3rd Gen truck help me with this question please? Here is the post. I need to get this truck fixed. Thanks in advance. I have checked all the fuses and found nothing blown.
"I have a 2007 Dodge Ram 1500 QC 5.7 Hemi with 166,000 miles on it. The other day when it got cold out it would not start. Just turned over. I thought it was just bc it was cold maybe. Later on when it warmed up I tried it again and no luck either. It will just try and start the one time and die off immediately. I pulled the codes with my superchips tuner and got one for P127E "fuel pump control circuit 2 open". It ran fine the night before when I drove it. I am assuming that this code probably means the fuel pump is bad? Or wiring issue to the fuel pump? I am down south and the closest Dodge dealer is about 40-50 miles away, so I would like to try and narrow it down a little before having the truck towed 50 miles to get it fixed. Anyone had their pump go bad and show this same code or was it a wiring/fuse issue? I haven't had a chance to check fuses etc yet, since I am working."
