NOcasio7
So as the title says my truck threw a P018C code yesterday morning. As far as trouble shooting goes, Friday evening I installed a Carven exhaust and went over the wires under the truck and nothing was obvious. When doing the exhaust I removed the muffler to the rear and then reinstalled with the new muffler and same pipes back. I looked into the code a bit and saw that it was common to be a fuel pressure sensor. I bought the sensor at the dealer and replaced it this morning. No change. I understand that some codes need the car to be driven for it to clear but with my scanner, it would not clear at all. Also what is weird to me is that if I start the car with the sensor unplugged, there is no code on my dash but if I scan with the OBD reader, I do still see the code. Has anyone experienced this or know what can be done? PLEASE HELP!! Thanks in advance all!!!
