idle ok, no power.
dgbirky
8.0 V10
2000 v10. the truck idles fine. no check engine light. when I step on the gas I hear a massive rushing sound, and there is no power from te engine. The engine acts as if either the exhaust is plugged or I am stepping on the brake while flooring the accelerator. if I idle and slowly accelerate keeping it under 2000 RPM I can slowly get up to speed but again no power and the rushing sound continues. 175000 on the truck.
Sounds like an issue I had with my jeep once, the catalytic converter was plugged. In my case you could let it run for about 15 min at idle then attempt to drive it for about 5 min and look under the truck and the cat was just starting to glow red from heat. Installed a new one and never had anymore issues.
Florida
Mag V10,Mag V8
Do like I did!!My (22 at the time) step son borrowed my truck ,'01 Dodge 2500 4x4 V10 488ci...for 45min one way drive to work 5 days a week...for three months!!Finally got it back he told me "You might need a tranny rebuild".Truck had no power,could hardly get out of its own way!!So I took it to a Tranny shop said "I think it needs a rebuild,has no power,no get-up-n-go".Guy said OK $1250 for the rebuild...I was like OK.4 days after rebuild got my truck back tranny shop guy told me "Oh...your truck got no power...no get-up-n-go...needs catalytic converter">I was like...DOH<DOH<DOH<No efin chit!!How 'bout that!! Made my slow ass way down to another shop...they charged me $100 to lop out the Cat...throw in a pipe...there ya go!!!
gofishn
Iowa
hemi 5.7L, 345 cu in
Cat X 3
