So I got the Magnaflow Catback system from Moes yesterday. Thanks Matt!
I pulled off the stock exhaust in about 15 minutes then began to install the new. Only problem is that the pipes that should slide over the two muffler outs are too small. Has anyone run into this? Design flaw, or I just get a bad fitting batch? This has turned an hour project into a 24 hour beat down.
Any words of wisdom?
