Need help finding a fuse.
mpress2570
So I was hooking up my dash cam on my 2017 sport. I don't have a trailer brake so I pulled down the plug for the trailer brake from under my dash. The one that is wrapped in foam. I used the plug with 4 wires connected to it to next to the trailer brake plug to wire in my dash cam. In the process I accidentally shorted it and blew a fuse. I can't find the fuse. I can't find a name for it or fuse number in my manual. Anyone know what fuse I blew?
If you don't know what I'm talking about I'll track down a picture since I'm not with my truck right now I can't take a pic of it.
Thanks for the help
mpress2570
mpress2570
Here is a photo of what I'm talking about. There is the big connector and small connector. They were tucked up in the dash above the gas pedal and wrapped in foam. The one I blew is the small 4 prong connector. Don't know what it would be under in the fuse diagram in the manual. Anyone with a name or the actual fuse number will earn the award of favorite member of the forums. 9286730e4a9522313dd56fe422d91cc4.jpg
Tach_tech
5.7L HEMI
I'm not at work right now so I can't look up the service information, but I would just grab a test light and check all the fuses under the hood. It'll only take a minute.
mpress2570
mpress2570
I found it literally an hour ago. It was F11
mighty noid
Culver City
Hydro Blue 2018 4x2 Sport Crew Cab
I want to hardwire my dash cam as well. So this 4 pin harness has constant 12V and a switched 12V on it?
