monettejb
2018 Hydro Blue Edition Ram 1500
- Nov 19, 2012
- 400
- 60
- Greenville, NC
- 2018
- Hemi 5.7
Chrysler has decided that a defect, which relates to motor vehicle safety, exists in some 2011 model year Ram 1500 series trucks.
The problem is...
The rear axle pinion bearing on your truck (VIN: xxxxxxxxxxxxxxxxx) may not receive adequate lubrication under certain driving conditions. This lack of lubrication condition could cause the pinion bearing to seize and cause a loss of vehicle control and/or a crash without warning.
What your dealer will do...
Chrysler will repair your vehicle free of charge (parts and labor). To do this, your dealer will install a pinion bearing fluid drain-back flow restrictor and a new axle cover with a revised fluid fill level access hole. The work will take about 1½ hours to complete. However, additional time may be necessary depending on service schedules.
The problem is...
