P0308
savage_46
Alaska
6.4 swapped
Tsb 18-093-15 addresses p0300 through p0308 in addition to other things. I have no way of checking what flash version is currently released. The flash may or may not fix your issue, but it's a good start.
fire101fighter
fire101fighter
South Jersey
Ok, so I switched the #8 and #4 injectors. I'll keep you guys posted. Thanks for the input so far.
fire101fighter
fire101fighter
South Jersey
Light cam back on. Scanner it this morning and it's p0304, so I'm headed to the dealer to get a new injector now.
THETANK
up jor *** mang
2015 R/T
not any help but time for a new truck maybe lol. Good luck with your issue.
Hootbro
U.S. Army Veteran
Delaware
2017 1500 Express 4x4
Pentastar 3.6L
Glad to see the problem traveled with the injector swap. Best practices though if you got the coin is replace all the injectors at the same time.
fire101fighter
fire101fighter
South Jersey
Yeah I wish I could, at $90 a piece that's probably not going to happen right now.
Hootbro
U.S. Army Veteran
Delaware
Pentastar 3.6L
Understandable. If you ever got the down time, there is companies that will rebuild and flow test you injectors for considerably less than buying new.
Rampant
NJ
392 Hemi
RockAuto has 5 different ones from $27 for aftermarket to $65 for Mopar... plus a 5% coupon and free shipping.
fire101fighter
fire101fighter
South Jersey
Sorry never updated the post but yes, the new injector did fix the issue. Thank god
am3334
