P0463 code on 2014 Ram
14RamMan
I havent had a check engine light on my truck since i purchased in new in 2014. 2 days ago, the check engine light turned on and the gas gauge dropped to zero (even though i had at least 3/4 of a tank). Got a "fuel sensor fail" message across the EVIC. I put some chevron Techron and some premium gas in it the next day, and cleared the code and all was well. The following day the check engine light came on, but the gas gauge appeared to be working fine. Same code; P0463. Any idea if this can be a big problem, or if its likely some bad gas? We're going out of town on our honeymoon in a few days and planned on taking the truck.
savage_46
Alaska
6.4 swapped
It's a common issue. Fuel level sensor needs replacement. I have yet to see it being wiring or module problem.
14RamMan
14RamMan
I'm guessing the fuel tank needs to be dropped for this? Is this something a local shop can do without breaking the bank?
Demon-HeMi
Houston
2003, 2003, 2008, & 2013
(2) 5.7 HEMI, 3.7, & 3.6
dealership replaced my fuel pump under warranty
SYKRAMMAN
Banned
Jersey shore
06 Mega
Unfortunately FCA hasn't been smart enough to put an access panel in the bed yet, so if you have a little mechanical aptitude, socket set and a jack then you can do it yourself fairly easily, just make sure you have an empty or close to empty tank. Shops around me charge around 300$ parts/labor.
Hemi395
Cape Cod MA
Was the Techron the Techron Plus? Reason I ask is the Techron Plus has a cleaner in it specifically designed to clean the fuel sender sweep contacts. I'd try that before dropping the tank and replacing the fuel pump module
14RamMan
14RamMan
I'll try the techron plus 1st. No harm in trying that route.
14RamMan
14RamMan
Looks like I'll have to replace the sensor and might replace the fuel pump while the tank is dropped.
Murphy Slaw
Southern Illinois
2016 Bighorn 4X4 Crew
Sounds like we should run the Techron Plus...........
I read something about Mercedes having the same issue.
Demon-HeMi
Houston
if i remember correctly the dealer told me it was all one unit when they did mine under warranty
i dont think its the gas, this seems to be a problem in 2014 mostly, im betting it was a bad production batch of pumps, i haven't had any of my friends have any pump failures on their trucks that weren't 2014
14RamMan
14RamMan
Did the pumps themselves fail? Im headed out of town and tracking the gas by miles. Hoping i dont end up stranded.
Demon-HeMi
Houston
my pump never failed, and i drove for over 2 weeks on mine, i took it to the dealer 3 times before they finally replaced it all...
i dont think its the pump failing, i think its just pretty much the fuel level sender
14RamMan
14RamMan
When the check engine light is on, and the fuel gauge is saying empty, the truck runs better than it usually does. It's more responsive, almost like some kind of eco mode is off. Is this a thing, and if it is, how can I get muy truck to run like this after I fix the sending unit?
mmcquinn
