Possible Suspension Issue?
jgruberman
EcoDiesel 3.0L
So I live on a tight street and park on the street side. I have a bad habit of U-turning and my driver tire hitting the curb, going up it then back down to the street. This morning I noticed what sounded like a metal clank and noticed the steering wheel is off center. The steering wheel may have been like this but I just noticed it today. Did I bust my ball joint?
Side thought, there seems to be a little extra wear on the outside of that tire, upper ball joint? (This isn't the first time I've heard the metal clank)
jgruberman
jgruberman
EcoDiesel 3.0L
You might need an alignment check
If I need an upper ball joint replaced, should probably do that first before the alignment? Or will the alignment not be affected by a bad ball joint?
stimpy433
IOWA
Ball joint needs to be fixed first.
jgruberman
jgruberman
EcoDiesel 3.0L
Assumed as much. Would that clanking be indicative of a ball joint? Or is it just possible I need an alignment and the clanking is just suspension components bouncing around as I hit and fall off the curb?
Sandbox
Warrenton, VA
6.4 HEMI
If it's clanking while the suspension is cycling, it could be the sway bar end links. You may have broke one of those.
jgruberman
jgruberman
EcoDiesel 3.0L
It's only clanking when I come back down off the curb, maybe up as well but I don't recall. Is that what you are saying when you said "cycling"?
12sportmc
NC
Does it look like this ??? Lol
Sandbox
Warrenton, VA
6.4 HEMI
Yes, that's what I mean by cycling. This one is an aftermarket link but, it should get you the idea.
jgruberman
jgruberman
EcoDiesel 3.0L
I'll check both the UBJ and sway link when I get out to the truck and post back.
whetrick1
If you have the alignment checked they can tell you if anything is wrong.
jgruberman
jgruberman
EcoDiesel 3.0L
IF it's a good alignment tech.
Doesn't appear as though sway link is broke or UBJ is popped.
whetrick1
That's why the alignment tech should be able to tell. It could be a tie rod end. Or possible broken shock.
