Limeybastard
- Jul 25, 2015
- 1,872
- 449
- 2015
- Hemi 5.7
While working on the underside of my truck I realized the passanger front body mount rusting, the rust appears to be on the trucks floorpan. Issue appears to be caused by the AC drain pipe further up. The area around the rust was wet by the way. The driver side is clean and rust free.
I think I will need to extend the drain hose and also extend it, so that its closer to the floor area thus to avoid pouring into all the nooks and crevices, the bolt where the frame to body is attached as mentioned is starting to corrode only on this location.
Truck is 2015 with approx 9k miles on it and located in florida.
Some pics.
Sent from my SM-N910T using Tapatalk
Some pics.
