- Apr 18, 2011
- 6,622
- 2,955
- Minot, ND
- 2014 Ram 2500 Crew
- 6.7L Cummins
So pinion bearing started howling again and it seems to be the bearing is likely failing. So far since I bought the truck with 27k I have put 3 pinion seals, u joints, and this will be the 3rd set of pinion bearings. I am beginning to wonder if the driveshaft is an issue since I have had issues with vibration and multiple installers have installed pinion bearings that have failed and seals that have failed. I have tried 3 brands of pinion bearings too, koyo, timken and some other napa brand.
Any thoughts chime in please.
