Go Back   DODGE RAM FORUM - Dodge Truck Forums > Dodge Ram Generations Forum > 4th Gen : 2009 - Present > Tech Info
Sponsored Ads
Register to remove these ads.
Tech Info
- Star Case - 4th Gen Torque Converter Moan, Drone, Rattle Issues
This is a discussion on - Star Case - 4th Gen Torque Converter Moan, Drone, Rattle Issues within the Tech Info forums, part of the 4th Gen : 2009 - Present category!
Register to remove these ads. It's free! Star Case: S1121000005 Release Date: 6/30/11 Symptom/Vehicle Issue: Customer indicates that the vehicle ...
View Poll Results: Torque Converter - Vibrations Moans Rattles
Have this issue 14 56.00%
Dont have this issue 7 28.00%
Noticed this issue but not worried about it 2 8.00%
Have you had the torque converter replaced 6 24.00%
Multiple Choice Poll. Voters: 25. You may not vote on this poll
Reply
Old 11-20-2011, 12:31 AM   #1 (permalink)
LU229's Avatar
Ram Year: 2010
Engine: Hemi 5.7
Default - Star Case - 4th Gen Torque Converter Moan, Drone, Rattle Issues
Customer indicates that the vehicle has a slight moan, drone, or rattle noise and sounds as though it is coming from the exhaust, The customer may indicate that the noise occurs under light load (1400 - 1700 engine rpm - around 40 to 60 mph)
Diagnosis:
Confirm that the noise only occurs while the torque converter is in lock-up at low speeds (around 1400 - 1700 engine RPM) at approximately 45 mph. If the noise is heard while transmission is in partial lock-up at 1400 - 1700 RPM, put the vehicle into ERS - Tow/Haul mode (deactivates MDS and torque converter in full lock-up) If the noise is unchanged, perform the following repair procedure. If the noise goes away in ERS mode, further diagnosis is required. If the noise occurs above 1700 RPM or below 1400 RPM, further diagnosis is required.
Parts Required:
AR (1) RL051167AB Kit, Torque Converter
(fits
2009 - 2011 2WD DS R/T Only)
AR (1) RL051146AB Kit, Torque Converter
(fits
2009 4.7L WK/WH/W2/XK/XH,
2009 5.7L DS/DC/DH/D1/HB/HG/WK/WH/W2/XK
2010 5.7L DS/DD/DJ/DX/WK/WH/XK/XH
2011 5.7L DS/DD/DJ/D2 Only)
AR (1) RL0512241AB Kit, Torque Converter
(fits
2008 4.7L 2WD ND/HB/HG/DR/WK/WH/XK/XH
2008 4.7L 4WD WK/WH/XK/XH
2008 5.7L 2WD/4WD DR/HB/HG/WK/WH/XK/XH
2009 4.7L 2WD ND/HB/HG/DS
2010 4.7L 2WD ND/DS/DX
2011 4.7L 2WD DS/DX/ND
2011 5.7L 2WD/4WD WD/WK/W2 Only)
Repair Procedure:
Replace the torque converter.
Follow the procedures identified in the service manual.
Notice for ALL forum members:
I am no way responsable for what is written here.
Just wanted to pass along this info and hope its helps some of you.
Maybe if we can have the administrators make us a sticky of this,
that would be good so that EVERYONE can use this information.
Thanks, and good luck folks....LU229
LU229 is offline   Reply With Quote
Old 11-21-2011, 07:31 AM   #2 (permalink)
quietpeen's Avatar
4th Gen / Site Mod
Ram Year: 2011 1500 Sport Quad Cab 4x4
Engine: Hemi 5.7
Send a message via AIM to quietpeen Send a message via Yahoo to quietpeen
Default
i voted that i do not have the issue, but now with my exhuast, i don't know if i would ever here a slight moan or droan.
__________________
RamForum.com Moderator
quietpeen is online now   Reply With Quote
Old 11-21-2011, 10:03 AM   #3 (permalink)
Ram Year: 2011
Engine: Hemi 5.7
Default
I think I may have this issue, I have noticed that my tranny is making some drone noise, will have to take it in and have it checked out. Or just wait until it does whatever it's going to do then they will have to fix it.
AirborneSilva is offline   Reply With Quote
Old 11-21-2011, 10:47 AM   #4 (permalink)
HEMIRT's Avatar
Ram Year: 2011
Engine: 5.7 HEMI
Default
Great info here, my truck has these symptoms. I thought maybe that's just the way theses trucks are. I'm taking mine in this week and having it addressed, along with the rear end howl.
__________________
HEMIRT is offline   Reply With Quote
Old 11-21-2011, 10:48 AM   #5 (permalink)
LU229's Avatar
Ram Year: 2010
Engine: Hemi 5.7
Default
Kinda like turning up the radio so ya cant hear a rattle....heheheheee
Old 11-21-2011, 10:51 AM   #6 (permalink)
LU229's Avatar
Ram Year: 2010
Engine: Hemi 5.7
Default
Absolute worse thing you can do, is to wait for something to break,
especially when you could have avoided it all together.
Old 11-21-2011, 11:01 AM   #7 (permalink)
LU229's Avatar
Ram Year: 2010
Engine: Hemi 5.7
Default
My 2010 truck has the same issues, trans groweling, rear diff howling.
Thats why i started this post on the trans issues. I`m curious to see how many 4th gen`s have the issue. I`ve been told by tons of people on all the forums that this trans issue isnt what it seems and nothing is really wrong with it. I`m finding out that i was right..! Ther is alot of these trucks out there with this very problem. And it dosent surprise me that some people dont even know they have this issue. I`d bet money that the people that say they dont hear the TC moan, drone, rattle, dont even know what to look or listen for. Its MY belief, every one of these 09, 10, 11, trucks have a noisey torque converter.
Some will ask, how do i know they`re all noisey...????
Because the clearence`s between the turbine hubs and the spline shafts are way to big. (very loose fit)
Thats why they are noisey, the lock-up is very irratic, wont lock-up properly, causes moan drone shudder rattle issues
Old 11-27-2011, 10:30 AM   #8 (permalink)
Ram Year: 2011
Engine: 5.7 Hemi
Default
My new 2011 has a moan when up to speed doing 60mph and the MDS has kicked off (going up small hill or windy day). When the MDS is active or when I put it in tow/haul mode the sound goes away. It has done this since 130 miles (first time I noticed it), so do I have a different problem or is this just normal for this truck?
XCELLR8 is offline   Reply With Quote
Old 11-27-2011, 11:25 AM   #9 (permalink)
LU229's Avatar
Ram Year: 2010
Engine: Hemi 5.7
Default
What exact model of truck do you have (???) The year is all you listed.
(SLT/SPORT/LARAMIE, 2wd/4wd, RegCab, Quad cab, Crewcab, SingleExhaust/DualExhaust)
Did you read the very first post/thread very carefully...???
Go back, re-read it, test drive, post results.
Before you road test, check your tire pressure(s) and set to factory spec.
Old 11-27-2011, 01:43 PM   #10 (permalink)
Ram Year: 2011
Engine: 5.7 Hemi
Default
Sorry for the lack of info, I was not thinking too clear after all the Thanksgiving parties...lol.
The truck is a 2011 SLT Quad Cab 4x4 with the Hemi, single exhaust, and 3:55 rear gears with limited slip. I did read both threads about this problem and did the road test on my way to work at 60mph. I will add to what I reported earlier, when running 60mph the motor is turning at 1500rpm in 5 gear with MDS on, when MDS kicks off the motor is turning at 1700rpm. When turning the tow/haul mode on the motor jumps up to 2250rpm. The tire pressures are reading 38psi and I have not messed with them since I bought the truck. I will do the test at 45mph later today and report back.
Reply
Bookmarks
Tags
gas pedal vibaration, star case: s1121000005, torque converter droan
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
DIY: Torque Converter Install OlDirtyJohn 3rd Gen DIY 18 03-22-2012 09:09 AM
Torque converter help moodygunner Engine & Performance 28 11-06-2011 11:43 AM
Torque Converter smiley3303 Engine & Performance 4 09-23-2011 01:15 PM
torque converter might be a no go :( RubberFrog Engine & Performance 90 07-25-2010 08:49 AM
Torque Converter is Here RubberFrog Engine & Performance 17 07-04-2010 08:37 AM
Fully Driven Auto Network
GM Truck Forum
Ford Raptor Forum
Chevy Tahoe Forum
Chevy Cobalt Forum
Chevy Camaro Forum
Toyota FJ Cruiser Forum
Ford Truck Forum
88-98 GM Truck Forum
73-87 Gm Truck Forum
Ford Expedition Forum
Chevy Equinox Forum
Chevy Cruze Forum
Jeep Liberty Forum
Jeep Forum
Dodge Ram SRT10 Forum
Chrysler 200 Forum
Scion xD Forum
Scion xB Forum
Dodge Challenger Forum
SRT Forum
Nissan Titan Forum
Buick Enclave Forum
Cadillac Forum
Cadillac XTS Forum
