CVMA Lonestar
Hi, I tried searching for this issue but couldn't find any posts, so if this is already covered please let me know. I have a 2012 with the ignition that starts the engine for you once you tip the key (don't know if there are 2012s without this feature). Every now and then, and more so recently, the starter stays engaged for too long. After the engine has already started I can hear it grinding for about a half second. Since this is an intermittent problem, I wanted to check if anyone has had this issue and knows a potential cause, before I take it to a shop and they charge me for nothing because they couldn't get it to do it there.
