Thanks for all your replies
Thanks for all the replies: Anyone wanting to tap into the 7 wire trailer harness, you can get a 18 gauge 4 wire trailer adapter at Walmart for $4.97. It will have a male and female, I just clipped the male adapter off and stripped wires and tapped directly into wiring harness right by the spare tire. Note: (if you want to make it easier to get to the wiring and make all the connections, you might want to drop the spare and get it out of the way. - Spent more time wiggling around it than it would have taken to drop it out of the way).
Truck Side wiring:
White/Orange - connects to the Yellow (Left Turn Signal) Walmart connector
White/Green - connects to the Green (Right Turn Signal) Walmart connector
Brown - connects to the Brown (Running Lights) Walmart connector
Black - connects to the White (Ground Wire) Walmart connector
