Go Back   DODGE RAM FORUM - Dodge Truck Forums > Dodge Ram Generations Forum > 3rd Gen : 2002 - 2008 > Tech Info
Sponsored Ads
Register to remove these ads.
Tech Info
04 Ram 1500 Hemi won't crank
This is a discussion on 04 Ram 1500 Hemi won't crank within the Tech Info forums, part of the 3rd Gen : 2002 - 2008 category!
Register to remove these ads. It's free! I'm trying to diagnose an 04 Ram 1500 Hemi that all of a ...
Reply
Old 01-06-2012, 05:30 PM   #1 (permalink)
Ram Year: 2004
Engine: Hemi 5.7
Default 04 Ram 1500 Hemi won't crank
I'm trying to diagnose an 04 Ram 1500 Hemi that all of a sudden would not crank. Friend had it towed home where I notice when turning the key to start, no sound(no solenoid click). Using wiring diagram, I had power up to the starter relay, but no ground. If I provide the ground and turn the key to start, it will crank. In looking at many wiring diagrams, I'm thinking the ground goes through the Transmission Range selector (45RFE trans) with switch inside the trans on valve body, but not sure since I don't have that wiring diagram, just Chiltons.
Other things I noticed (that the friend said happened at the same time):
1. Speedo and Tach sweep to full clockwise and stay there while key is on.
2. If I move gear shifter while stepping on brake with key on, there is no gear range indicator. Shows the P-R-N-D etc but no idication which position it's in. I verfied that the transmission lever is physically moving at the trans side.
3.When I hook up two code scanners to the OBD2 port, both come back after trying to negotiate the protocol that there is no communication with the vehicle. Verified there is gnd on pin 5 and +12 at pin 16 of the DLC.
4. I can hear the fuel pump and ASD relays cycling on-off-on-off as long as the key is turned on. Tried swapping relays(starter relay earlier, ASD and Fuel pump) with identical ones, same result. I see voltage fluctuate when the relays pick while they are cycling on and off.
5. Undid all the fuse box and PCM connectors to look for corrosion and loosened an re-tightened all the grounds that I could see in the engine compartment. Pulled each fuse out to visually inspect.
I'm tired and lost...any ideas?
thanks guys.
Kimo is offline   Reply With Quote
Old 01-06-2012, 08:10 PM   #2 (permalink)
KGBIGCOUNTRY's Avatar
3rd Gen / Site Mod
Ram Year: 2004 RCSB/2005 QCSB
Engine: 5.7 / 5.7
Default
Has there been a tuner installed ever on the truck and has it been recently changed or tampered with? I'm leaning towards to computer has freaked out seeing you have checked most of the common issues.
__________________
RamForum.com Moderator
Its Tweaked & Twisted
Crazy Spartan on a 112lsa Thumping It, PWR Heads Opening It Up, Coated Pacesetters Doing The Rest, Tuned by Spooldu with DSP
Powed and Tuned by King Motorsports
KGBIGCOUNTRY is offline   Reply With Quote
Old 01-06-2012, 08:26 PM   #3 (permalink)
BlackedOutHemi's Avatar
Ram Year: 2008 & 2012
Engine: 5.7L HEMI & 6.7L Cummins
Default
Computer problem.
__________________
Black Truck Club #30 Texas Truck Club #1
BlackedOutHemi is online now   Reply With Quote
Old 01-06-2012, 10:27 PM   #4 (permalink)
The Assassin's Avatar
Ram Year: 2006
Engine: 4.7
Send a message via Skype™ to The Assassin
Default
+1 on computer.
__________________
2011 SEMA Feature Vehicle, Truckin' Magazine
Custom painted Ram Club Member #1
Shaved Ram Club Member #1
Ram Forum After Dark Member #1
Supporting Member Club Member #1
The Assassin is online now   Reply With Quote
Old 01-06-2012, 11:05 PM   #5 (permalink)
Ram Year: 2004
Engine: Hemi 5.7
Default
Thanks for the responses. I checked things based on things I've read from this forum. Kudos to all of you guys. As for any mods, no, this truck is bone stock. Not even an aftermarket alarm system. Get this, I also noticed that if you leave the key in the on position for at least 20 seconds, the odometer increments 1 mile. I'm guessing because the speedo is registering 120mph! I'd like to be able to diagnose the PCM before swapping out, but I guess this is so weird that I might have to easter egg this one. Thanks again for your thoughts. Any other ideas?
Old 01-08-2012, 06:10 PM   #6 (permalink)
HemiBabe's Avatar
3rd Gen / Site Mod
Ram Year: 2004
Engine: 5.7 HEMI
Default
What in the world??? lol that is crazy!! I have never heard of that happening, it's gotta be the PCM I would think..?
__________________
HemiBabe is online now   Reply With Quote
Old 01-08-2012, 07:06 PM   #7 (permalink)
3rd Gen / Site Mod
Engine: 5.7 / 5.7
Default
Might need it reflashed. For some reason I recall there being a PCM problem on certain part numbers. Check with your local dealer to see what they charge to reflash the computer.
__________________
Old 01-09-2012, 04:17 AM   #8 (permalink)
Ram Year: 2004
Engine: Hemi 5.7
Default
Thanks, will look into that or buying a refurbished and guaranteed PCM to see which is more feasible. I was hoping it's some sort of bad power or ground to the PCM, but not real anxious to go through that exercise unless I have great instructions and diagrams for locations.
Thanks all for your input. I will post back if/when I get the fix. (might end up sending the friend to a dealership).
Old 01-31-2012, 03:09 AM   #9 (permalink)
Ram Year: 2004
Engine: Hemi 5.7
Default
Well, I was able to get a PCM from an identical truck for testing. It started immediately without any of the symptoms I noted before. I guess a choice would be to have the dealership reflash the "new" PCM with the VIN and mileage or get one online someplace. I just wanted to feedback that the PCM was the problem in my case. Whew!
Thank you all for you input and comments. You guys nailed it.
Old 01-31-2012, 07:48 AM   #10 (permalink)
3rd Gen / Site Mod
Engine: 5.7 / 5.7
Default
Good deal man, stick around and have some fun.
__________________
Reply
Bookmarks
Tags
dodge ram wont crank, ram computer issues, ram pcm problems, ram will not start, wiring on dodge ram
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
07 ram 1500 hemi 4x4 tow 4 wheels down Bud404 General Discussions 10 10-19-2011 05:10 PM
03 ram 1500 5.7 hemi for sale/trade AJMAG For Sale 7 09-17-2011 10:30 AM
2003 ram 1500 hemi? Little Dodge Guy General Discussions 0 08-17-2011 09:04 PM
Ram 1500 5.7 hemi 4x4 2009 bajamovil Engine & Performance 1 07-02-2011 08:30 AM
Fully Driven Auto Network
GM Truck Forum
Ford Raptor Forum
Chevy Tahoe Forum
Chevy Cobalt Forum
Chevy Camaro Forum
Toyota FJ Cruiser Forum
Ford Truck Forum
88-98 GM Truck Forum
73-87 Gm Truck Forum
Ford Expedition Forum
Chevy Equinox Forum
Chevy Cruze Forum
Jeep Liberty Forum
Jeep Forum
Dodge Ram SRT10 Forum
Chrysler 200 Forum
Scion xD Forum
Scion xB Forum
Dodge Challenger Forum
SRT Forum
Nissan Titan Forum
Buick Enclave Forum
Cadillac Forum
Cadillac XTS Forum
