11-15-2010, 06:20 PM
#141 (permalink)
Ram Year: 2006
Engine: 5.9 CTD
Tsb 14-001-10 : Dtc p0251
Register to remove these ads. It's free!
Service bulletin #: 14-001-10
replacement sb#:
Nhtsa item #: 10033546
date: 20100202
failing component: 092100 fuel system, other: Delivery:fuel pump
make: Dodge
model: Ram
year: 2003, 2004, 2005, 2006, 2007
date created: 20100823
description of summary: Dodge: Electronic fuel control actuator (fca) available for service/new diagnostics available for dtc p0251. Engine surges at idle or mil illumination. Further investigation may identify dtc p0251-cp3 pump regulator control-diesel. If p0251 is present, follow the diagnostics in this sb. If other dtc's are present, repair as necessary before proceeding further. Model ram truck. *pe
