Go Back   DODGE RAM FORUM - Dodge Truck Forums > Dodge Ram Generations Forum > 3rd Gen : 2002 - 2008 > Tech Info
Tech Info
Ac blower?
This is a discussion on Ac blower? within the Tech Info forums, part of the 3rd Gen : 2002 - 2008 category!
I have an 08 1500. The blower will stop working intermittently. Sometimes i turn the truck on and it works ...
Reply
Old 09-10-2016, 11:55 AM   #1 (permalink)
Ram Year: 2008
Engine: Hemi 5.7
Default Ac blower?
I have an 08 1500. The blower will stop working intermittently. Sometimes i turn the truck on and it works but 10min into a drive it cuts out on all speed settings. Sometimes it doesnt work from ignition until halfway through the trip. Also it will blow on a setting from time to time but increase speed as i increase speed. I work on artillery in the army so i can trouble shoot but im lost with wheeled vehicles. Any ideas on where to start?
Sponsored Ad
Register to remove this ad.
Dylan08ram is offline   Reply With Quote
Old 10-04-2016, 09:48 PM   #2 (permalink)
Bevan's Avatar
Ram Year: 2008
Engine: Next Gen V8 4.7L
Default
Check your blower motor resistor for cracks or might be dirty.
Bevan is offline   Reply With Quote
Old 11-16-2016, 04:44 PM   #3 (permalink)
Ram Year: 2004
Engine: 5.7 hemi
Default
Similar issue here. Ignition switch. Not the keyed side, but under the steering column cover on the other side. Disconnect the hot wire from the battery first. Air bag inflator is in there somewhere, no need to set that off. The plastic lever on the tilt assembly will just pop off, pull it back towards you. 3 screws to remove the cover, t-20. 2 screws to remove the tilt assembly, not sure size but they are torx, 2 screws to remove the switch assembly, torx also. Remember what screws came out of which location, one is short and one is long. Disconnecting the cable is a bit tricky, as is locking it back on. Make sure the plastic piece inside the new one lines up with the keyed part. I used a hex allen to rotate it just a hair. Then, it's just a matter of attaching everything in reverse order, lining up the covers and making sure they fit right. This is an 04 I did, so yours should be the same, or very close. This was the cheapest part to replace I think, maybe the resistor is about the same $. Around 25 to 35 dollars, depending if you get it online or at a local parts store. If this doesn't solve it, then the motor, or the control unit. Both not difficult to replace, for me, and I'm not an automotive rocket surgeon.
snuffysmiff is offline   Reply With Quote
Reply
Bookmarks
Tags
blower motor help
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Blower Cams? Gamester Engine & Performance 12 06-30-2016 01:54 AM
Blower fan issues Koldsteel General Discussions 0 06-05-2015 11:16 AM
Blower Issues, What can I do? keentopgunner Tech Info 2 04-29-2015 12:45 AM
Blower Motor austinmckinstry General Discussions 1 01-20-2015 04:16 PM
Blower Resistor michaelmurphync Interior 1 11-17-2013 11:38 PM
GM Truck Forum
Ford Raptor Forum
Chevy Tahoe Forum
Chevy Cobalt Forum
Chevy Camaro Forum
Toyota FJ Cruiser Forum
Ford Truck Forum
88-98 GM Truck Forum
73-87 Gm Truck Forum
Ford Expedition Forum
Chevy Equinox Forum
Chevy Cruze Forum
Jeep Liberty Forum
Jeep Forum
Dodge Ram SRT10 Forum
Chrysler 200 Forum
Scion xD Forum
Scion xB Forum
Dodge Challenger Forum
SRT Forum
Nissan Titan Forum
Buick Enclave Forum
Cadillac Forum
Cadillac XTS Forum
