Daytona#4595
- Jan 20, 2015
- 15
- 21
- 2005
- 6.8 L stroker
Hi all,
A couple of things for my 2005 Ram Daytona 4x4 6.1
A. External Fuel Pump
B. New Diff Gears
I need to replace my fuel pump in my 2005 Ram 1500 Daytona with my new 6.1 Beast and hate dropping the tank. I am thinking to drop it and switch to an external Fuel Pump and regulator and an external filter assembly.
I have read up on the bulk head fittings and they are pretty simple.
Any brands that work better than others?
Has anyone had any leakage issues with them?
I am thinking to install two an6 bulk head fittings in the top of the tank.
One for pickup and one for return. I will set the pickup strainer inside the sending unit support where the oe pump pickup is. I feel this would be better to prevent starvation from sloshing fuel when the fuel level is low.
I am leaning towards a Bosch 044 pump for 2 reasons. They are reliable and if it fails while I am traveling I can easily find one to replace it.
Any comments?
My engine is naturally aspirated,
Any recommendations for a pressure regulator?
What Fuel Pressure should I set it too?
Also I want to change my fuel rails so I can install the regulator on the outbound side of the rails.
Any recommendations on rails?
B. Diff Gears
My ft and rear diff are 3.92 and the power curve from the 6.1 could use some shorter gears.
I have 20" wheels with 36" tires
In OD at 70 MPH I only tach 2200
I am thinking of jumping to 4.56 gears ft & rear
Any recommendations on the best Gear manufacturers?
Also can someone with similar tire size and 4.56 gears tell me what they think about them and also what do you tach in OD at 70mph
PS, LOVE the HP from my new 6.1 engine!!!
Thanks,
Rob
B. New Diff Gears
Any comments?
B. Diff Gears
Thanks,
Rob
