front differential ?
jhemi
wisconsin
Today i was turning around and needed to put truck in 4wd to get out of ditch, and the passenger side axle came apart at the nuckle, and broke the differential cone bracket to frame, question is can i disconnect front drive shaft and drive the truck the way it is with out loosing fluid, until i can find the parts i need? and where can i find just a new nose cone for the diff?
quietpeen
2021 TRX
Hellcat
oh damn, i wish i could answer that.
rambob
LA/MS
318 5.2l
I really dont think so.
03MopaRamman
RAM SPORT / 18 SRT
Southern Alberta
Aluminum Frame to Housing mount portion with 2 bolts? Not sure what you mean by Cone.
That s Terrible man, sorry for the bad Luck. If the housing is broke you may need a used C205 with same gear match as yours.
Ultimately you will need not one but 2 1/2 shafts as well as the other one could do the same. I am guessing you have approx 120 k Miles as they do not last much longer.
I would not run on it if the diff housing was not secure as the other halfshaft could vibrate the whole unit even with the driveshaft out and of course removal of that other broken 1/2.
Good Luck and again Sorry to here this jeff.
iSlacker816
Kansas City, MO
5.9 (360ci) Magnum
Yea better off posting some pics, not sure about the part names you're using
jhemi
jhemi
wisconsin
thanks for the replys, been busy ive put about 100 miles on it since yesterday, holding up sofar both 1/2 shafts are going to have to be changed thats not a concern, the part that broke concerns me, dont have a choice in driving it all my money ******* in court for custody of my daughter, il get a pic up within the hour
jhemi
jhemi
wisconsin
couple of pics,
looks like just that piece can be tookin off the differential but not sure, even bien broke i can hang on it and it doesnt move but still dont feel safe driving it
