Go Back   DODGE RAM FORUM - Dodge Truck Forums > Dodge Ram Generations Forum > 3rd Gen : 2002 - 2008 > Tech Info
Tech Info
Front End Woes
This is a discussion on Front End Woes within the Tech Info forums, part of the 3rd Gen : 2002 - 2008 category!
Hi everyone. I would like some suggestions on a DIY project I have in mind. I have a 2003 with ...
Reply
Old 12-05-2016, 09:15 PM   #1 (permalink)
2003MOPAR's Avatar
Ram Year: 2003
Engine: 4.7
Default Front End Woes
Hi everyone. I would like some suggestions on a DIY project I have in mind. I have a 2003 with 75K miles on it and the usual things are starting to wear out. Top of my list is the rack & pinion. I think I can do this repair in my driveway with limited need for specialized tools. I think.
What I would like to know is are there any "special" tools required? I have yet to look at a repair manual so I know that would answer my question. But what fun would that be? I'd like to give you guys the opportunity to weigh-in and offer suggestions before I start banging my knuckles on the undercarriage.
2003, 4.7L, Standard Cab, Short bed.
Sponsored Ad
Register to remove this ad.
2003MOPAR is offline   Reply With Quote
Old 12-05-2016, 09:31 PM   #2 (permalink)
SilverStreak88's Avatar
Ram Year: 2007
Engine: 5.7 Eco Gasser
Default
Just need a good socket set, a ball joint separator for the outer tie rods and some patients. Probably Allen Keys as well for the steering shaft at the gear box.
__________________
SilverStreak88 is offline   Reply With Quote
Old 12-06-2016, 08:41 AM   #3 (permalink)
HemiLonestar's Avatar
Ram Year: 2003
Engine: 5.7 hemi
Send a message via AIM to HemiLonestar Send a message via Yahoo to HemiLonestar
Default
At 75k you're needing to do this? I just now did my front end and my R&P is still good at over 160,000.
__________________
2003 Ram 1500 QC Hemi Lonestar "Big Red" & 2006 Charger R/T "Little Red"
SRT-10 suspension, brakes and interior parts, Circle D, 1 ton trans cooler, Bilsteins, Superchips, AiRaid, Taylor shorties, McGaughy's shackles, Borla cat-back, Daytona lip, tow mirrors, SRT-10 hood.
HemiLonestar is offline   Reply With Quote
Old 12-26-2016, 03:50 PM   #4 (permalink)
pajeepman's Avatar
Ram Year: 2003
Engine: 5.9 magnum
Default
Bought my '03 in December 2015 with 85k on it. It needed a rack then, still needs it. Leaks and has hardly any steering when very cold until I cycle the steering wheel back and forth a little bit a few times. Looks easy to do.
Sent from my SM-J320P using Tapatalk
pajeepman is offline   Reply With Quote
Old 12-27-2016, 12:36 PM   #5 (permalink)
Ram Year: 2003
Engine: 4.7
Default
Getting ready to do my 03 1500 QC. I'll be replacing the PS pump, high pressure line and adding a filter to the return line first. If the leak and noise clears up (I don't think it will) I'll install the R&P from a donor truck and moog tie rod ends which I already have. The only thing that concerns me is the torque on the mounting bolts. Looks to be either 235 ft/lb which will be harder on my shoulder than I'd like to think about. I had to use a 30" crescent wrench on the back nut to get it off the donor...
axshon is offline   Reply With Quote
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
A/c woes. ST-8 General Discussions 3 10-21-2016 04:00 PM
Saving grace for your front park sensor woes fcreamer88 Tech Info 1 12-31-2015 12:09 PM
Front end woes meistermash General Discussion 9 07-24-2014 01:56 AM
Front end woes Stj0482 Tech Info 3 11-07-2011 09:43 AM
A.C. Woes MOPAR78 General Discussions 13 07-18-2010 04:03 PM
GM Truck Forum
Ford Raptor Forum
Chevy Tahoe Forum
Chevy Cobalt Forum
Chevy Camaro Forum
Toyota FJ Cruiser Forum
Ford Truck Forum
88-98 GM Truck Forum
73-87 Gm Truck Forum
Ford Expedition Forum
Chevy Equinox Forum
Chevy Cruze Forum
Jeep Liberty Forum
Jeep Forum
Dodge Ram SRT10 Forum
Chrysler 200 Forum
Scion xD Forum
Scion xB Forum
Dodge Challenger Forum
SRT Forum
Nissan Titan Forum
Buick Enclave Forum
Cadillac Forum
Cadillac XTS Forum
