Go Back   DODGE RAM FORUM - Dodge Truck Forums > Dodge Ram Generations Forum > 3rd Gen : 2002 - 2008 > Tech Info
Tech Info
Heat works and then it doesn't
This is a discussion on Heat works and then it doesn't within the Tech Info forums, part of the 3rd Gen : 2002 - 2008 category!
I'm helping a friend with his 2006 5.7 Hemi. The heat works when you first turn the fan on for ...
Reply
Old 11-15-2016, 09:39 PM   #1 (permalink)
Ram Year: 2006
Engine: 5.7 Hemi
Default Heat works and then it doesn't
I'm helping a friend with his 2006 5.7 Hemi. The heat works when you first turn the fan on for about 30 seconds and then fades to cool.
What I've discovered:
1. The truck doesn't seem to be overheating, It comes up to temp and doesn't fluctuate. Coolant level is fine and radiator seems to be working.
2. The recirculation door is broken and has been removed.
3. The mode selector (the one that changes where the air is blowing) doesn't work. I assume that the door is broken on this as well.
4. Hot/cold air mix seems to be working. Motor will move the doors and it feels as if the bottom door is at least intact. I didn't take it apart far enough to test the top door.
5. Only one of the lines to the heater core gets hot. I checked after the truck had been running for about 20 minutes. After about an hour both lines were hot.
6. Turning the fan off for a minute and the turning it back on will result in the same hot then cold cycle.
I'm unsure of which direction to go with this thing right now. Any help would be appreciated.
Sponsored Ad
Register to remove this ad.
Schammy04 is offline   Reply With Quote
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Fog light issue. One works, one doesn't NUTT00 Audio & Electronics 3 04-10-2017 09:43 PM
Heat and Heat Vents Mega Mike Tech Info 11 01-08-2013 06:58 PM
Heat doesn't always work. RompinRam Tech Info 2 01-21-2012 01:21 PM
No heat and fan only works on high mear5005 Tech Info 12 12-20-2011 02:14 AM
GM Truck Forum
Ford Raptor Forum
Chevy Tahoe Forum
Chevy Cobalt Forum
Chevy Camaro Forum
Toyota FJ Cruiser Forum
Ford Truck Forum
88-98 GM Truck Forum
73-87 Gm Truck Forum
Ford Expedition Forum
Chevy Equinox Forum
Chevy Cruze Forum
Jeep Liberty Forum
Jeep Forum
Dodge Ram SRT10 Forum
Chrysler 200 Forum
Scion xD Forum
Scion xB Forum
Dodge Challenger Forum
SRT Forum
Nissan Titan Forum
Buick Enclave Forum
Cadillac Forum
Cadillac XTS Forum
