truckin151
May as well add it to your list at the very very very bottom, if you go through every option, pull the sidewinder and put the stocker back in and see how it runs.
that is not happening...
I said very last resort.... if another few weeks pass and you are still out a truck cause it won't run, id be pulling it apart again and redoing it
Random thought, did the cam come with the +4* cam gear. I think the sidewinder uses one but not 100% sure
Not needed, the +4 is ground into the cam.
I hate to say it but as a last resort that is about all that is left. Pull it apart, go step by step and retrace everything until you find the problem. It sucks but that might be what this ends up coming too if the other things don't fix the issue.
