09-09-2011, 09:52 AM
#4 (permalink)
Ram Year: 2001.5
Engine: Cummins
The key trick, on, off, on, off, on, quickly will tell the computers to display the error codes in the odometer window. When you do this, make sure to have a piece of paper and pen ready. If there are no codes you will see a PdOnE and an EdOnE and they will look like this. The key trick does work on most Chrysler products, yet those before 2001 it may only show the P codes and not the E codes. I am not sure if the key trick will work on other makes of vehicles.
__________________
O.O., 01.5, Dodge, 2500, H.O.(245/505), 6 Speed/NV5600, 3.55's, 4x4, QCLB, Sport, 99,999, currently stock engine, K&N Air Filter, 285/75R16s, Glow Shift Gauges: FP, Boost, EGT, Oil Temp, SMARTY@1, lift pump 19@idle, 14@WOT, Propane, 2 Stroke, IAT Fooler = Better MPG, more to come!!
Toys:
'79 CJ5, 258ci, 3" lift, 35's, Stock Engine and 3 Speed Tranny
'05 Suzuki, GSX1300R, Hayabusa, All Stock, #3('00 blown engine, '00 stolen, & '05)
'05 Honda, CRF250X, Leg Breaker
