truckin151
What way should the inline IA/MAF sensor be possitioned? Should it be so that it is laying "flat" in the air steam (cannot see the blue part of the sensor) or should it be "blocking" the air stream (can see the blue part of the sensor)? And would it make a difference if it is one way or the other? I went through and made a few adjustments to my CAI today and while it was turned so that it was blocking the air stream I was getting the same idle surging issues as I was before, when I rotated it 90* so that it was laying flat in the air stream and let it learn a little the idle issue seems to have gone away. So I am curious if this makes a difference and which way it was suppose to be.
