04 Dodge Ram 2500 5.7 hemi my check engine light is on and computer says random multiple misfire code is thrown so I changed the plugs, wires and coil packs which were all still stock so they needed changed but didn't fix the problem. Does anyone have any ideas of what could be wrong? I don't wanna throw money at it and still have issues
When tracking down misfires, I do the following:
1. Plugs
2. Wires/coils (check the harness as well)
3. Compression Test
4. Fuel Injectors
I tracked down a misfire on a jeep for years. It was on one cylinder, and it passed all tests. Turns out the problem was a hardened inner o-ring on that injector. I pulled the injector out, and the o-ring was missing. I looked inside, and it was stuck in the block. I took a pick and pulled it out, it was hardened and brittle. I put the o-ring from the new injector on the old injector, and the problem was gone.
Not saying this is your problem, but just wanted to show how the smallest thing can affect these modern engines.
In my case it was cylinder 3 (303 code), it just came and went. When it is multiple cylinders, I typically lean towards damaged harness, or head gasket (easy to tell from a compression/leak down test).
