badblackram06
I found that my pinion seal is slightly leaking on my truck. I've never really changed one of these things out but i know as much to remove the drive shaft and unbolt the yolk plate that the drive shaft bolts to. How do i go about pulling the old one out and putting the new one in? Will any fluid come out when i remove the seal? Enough that i have to add some? I may be wrong, but it looks to be pressed in but has a outter lip like maybe i can use a flat chisel to pop it out. I just want to do the job right the first time and not have to redo it later down the road. Any help would be great. Thanks
