02-15-2011, 12:37 PM
#1 (permalink)
Ram Year: 2003
Engine: 4.7 Magnum
No heat and running warm
Long story short. 2003 Ram 1500 Quad Cab with a 4.7
Fall of 2009, no heat, temp guage in normal range. Replaced heater core. Heat returned.
Summer 2010, Coolant tank on top od Rad leaking, temp guage normal range. Tank changed. The very next day, red check guage light, temp guage almost maxed out. Luckily, a block away from dealer. Rad clogged.
Rad changed.
Winter 2010, takes for ever for temp guage to start climbing after start, little to no heat when very cold outside temps, temp guage levels out about 1/8" before half way mark. Thermostat changed, some heat returned, still takes awhile for temp guage to climb, now levels out at the half way mark. Pretty much stays there at highway and city stop and go driving. Shut off truck for a few minutes to run an errand, and temo guage is at 3/4 mark after restart, Returns to half after driving resumes. No overheating or hot coolant smells inside or outside of truck. Suspect dealership did a poor or no flush when core and rad were changed. Do I need to try a core back flush, in conjunction with a complete system flush? If so, which hose should be the inlet hose to the core? They both feel the same temp to me. Is it the one with the "T', or the straight one to the water pump?
Sorry, not so short after all. Any ideas? Thanks in advance.
