ramhunter9
- Jun 25, 2010
- 24,464
- 974
- 2012
- P-Star Jeep Wrangler
As you all may know I dont really drive my truck much , but this winter I have more than most .
I have a issue I cant track down and need some input .
For some reason my truck likes to eat battery's .
Here is the skinny .. thought I had a bad battery , took it in for a test it was low reading 11 volts not 12 . But after a our on the charger is tested 100%
So I thought the alt was bad ... had it tested .. 100%
So I did a code scan .. got Battery Low Voltage ... duh
Lost com with radio .. probably because im not running stock
And this one ? Condenser fan control circuit open ? Now I looked and traced everything does this dam thing have a relay ? Pulled all the fuses in the box all were good except the cig lighter .
I have no idea what is killing my battery .
If you have anything to add that would be awesome
The code for the fan was B10CO
