P0300 - Random Misfire
AF_Hemi
Central Jersey in person, the burgh at heart
2013 Ram 1500 CC 4x4 Sport
Help me troubleshoot. Gettin a P0300 code for Random Misfire Detected.
For some reason it seems like the truck is erasing the PCM when the truck is off for a while. I can start the truck fine, but it idles real shaky and tries to stall until i get about 15 miles on it when the pcm learns the tune again. Twice now its actually stalled coming up to a stop sign -- something its never done before.
Any ideas?
KGBIGCOUNTRY
MECH, VA
2004 RCSB/2005 QCSB
Have you checked the battery? You could be loosing some charge on it then it when its running the alt is bringing it back after a few? That could poss explain the computer acting ******** till it runs for a few? Just tossing out an idea.
KGBIGCOUNTRY
MECH, VA
2004 RCSB/2005 QCSB
PCM takes a constant 12 volt supply, is Marty still around to ask?
AF_Hemi
AF_Hemi
nope he's deployed. Its not about volts. Using that argument a 10,000w sound system uses the same power as an LED. true they both use 12v, but its the amperage draw that makes the difference.
I've read other places that a P0300 is normal with a cam. Not sure why, but apparently its nothing to worry about. I just wonder why its just not popping up when i've had the cam in for several months
ramhunter9
P-Star Jeep Wrangler
sounds like you need a new CTD megacab on 40's .
AF_Hemi
AF_Hemi
dont freaking tempt me. i just got promoted which comes with an extra $1500 a month. im trying to do the responsible thing and get completely debt free in 2 yrs. comments like that make it tough
ramhunter9
CTD rollin on 40's....ohhh awwww
KGBIGCOUNTRY
MECH, VA
2004 RCSB/2005 QCSB
So I am corrected, if I get a P0300 misfire with my new setup I will let you know.
KGBIGCOUNTRY
MECH, VA
2004 RCSB/2005 QCSB
A_F what ended up with Chefferds truck when he ran into that recently? Yall are both using DSPs I believe maybe its something simple I cant remember much about his last problem other then the random misfire also.
03MopaRamman
RAM SPORT / 18 SRT
Southern Alberta
Is your intake leakin anywhere, Just a thought!
harleyowners0709
yes i just went though the same thing my mech.found a broken valve spring on cyl.num one they are noted for them he said
03MopaRamman
RAM SPORT / 18 SRT
Southern Alberta
Sorry to hear about your spring breakage but a P300 Random...Hmmm....thats odd.
Got one the other day after a WOT run while doing a fuel injector cleaner Tank of Fuel and tends to do that just before or during the cleaning process. On a newer Tank of Fuel now and everything seems good/bsck to normal. Did some 80 mph 2500 RPM overdrive runs on the Hwy. If it comes back I will pay and get The Caustic $189 Solution Hooked into my Fuel Rails as I got 244,000 km anyhow and have never had them professionally cleaned as other folks usually don't touch my Truck unless its Tires, alignement, or exhaust.
KGBIGCOUNTRY
MECH, VA
2004 RCSB/2005 QCSB
Blast from the past here, the random misfire code is a side effect of some cams is what is claimed... neither of my two cams tossed that code, that being said its possible the tune was slightly off on timing. That KRC cam had alot of quirks.
OlDirtyJohn
Naha-shi, Okinawa, Japan
2004 Quad Cab 2500 *Sold*
i usually just take the fuel rail off, pop the injectors out, and clean them by hand. its not a bad process at all. rather easy actually.
