realflow100
- Jul 24, 2016
- 13
- 0
- 1999
- it is 1500 model 5.2L stock
I thought this was an okay place to ask
Ive got a 12v battery and when I take the plastic cover/lid off to expose the battery cap vents
I notice 2 things about the battery
Theres teeny tiny droplets of liquid all around. (wiped up with a napkin and q-tips)
inside the battery vents when I look with a flashlight into the cells I notice theres a decent "layer" of excess liquid floating on top of the seperators about a mm thick sloshing around wanting to get out.
I went in the cells with an army of q-tips and slowly soaked the excess away one q-tip at a time until it didn't slosh/move when i moved the battery gently and tilted it slightly.
cleaned everything up with a few more q-tips and now theres no problem with excess liquid. and put all the used q-tips into a sandwich bag to throw out
It was like that when I bought it brand new. it read 12.78v fresh out of the box.
When I first took the plastic cover/lid off the rubber caps were sucked inwards.
after charging they were outwards and had a bit of pressure in them but not much. (just enough for a little bit of bubbles to come out under them when i push on them with my finger)
did I get a defective battery? or is it like super fresh new from the factory and possibly had excess fluid in it that squrged out on the first use or so?
it has very smooth clean-room like surfaces on the outside so i'm assuming its new and hasnt been used. with a label on the front
on charging it couldn't of been overcharging because the current dropped to only 0.2A and the voltage only went to 14.6v at the very end of the charging stage. and the battery stayed room temperature.
I was monitoring the voltage the whole time and it slowly rose to 13.2v then slowly rose to 14.6v and stayed around there pretty closely. with the current dropping gradually.
On the battery it says Cycle voltage 14.4v to 15v and standby 13.5v to 13.8v
that sounds like its within charging range?
What could really be the cause of the excess liquid escaping?
I'm thinking of super-gluing the plastic cover/lid back on for now.
