Go Back   DODGE RAM FORUM - Dodge Truck Forums > Dodge Ram Generations Forum > 2nd Gen : 1994 - 2002 > General Discussion
General Discussion
1740 code
This is a discussion on 1740 code within the General Discussion forums, part of the 2nd Gen : 1994 - 2002 category!
I just bought a 2001 5.9 off-road that has come with a 1740 code. I have found the code is ...
Reply
Old 12-22-2016, 08:20 AM   #1 (permalink)
Ram Year: 2001 offroad
Engine: Magnum 5.9
Default 1740 code
I just bought a 2001 5.9 off-road that has come with a 1740 code. I have found the code is tied to the tcc. For a few bucks I'll replace the filter,fluid and all the solenoid. My question is
What is the easiest way to replace the tcc/od solenoid? Should I remove the valve body or just the thing at the end with the three torch. I know there are two springs in the second method that could make it a pita. Are there any issues with removing the valve body? I am handy but by no means a transmission expert.
Sponsored Ad
Register to remove this ad.
Sterling is offline   Reply With Quote
Old 12-22-2016, 08:53 AM   #2 (permalink)
Engine: Magnum 5.9
Default
I know there is a chance my torque converter clutches are worn. If this is the case would I see crap in the pan when I drop it?
Obviously I'm hoping it is a clogged filter or a bad solenoid. They are much cheaper and easier. But before I throw money and time at the solenoid I want to see if the torque converter is already bad.
Old 12-22-2016, 08:55 AM   #3 (permalink)
Engine: Magnum 5.9
Default
Oh. The fluid is still red and doesn't smell burned.
Old 12-22-2016, 09:25 AM   #4 (permalink)
dapepper9's Avatar
Ram Year: 2001
Engine: 5.9L V8
Default
I would drop the valvebody BUT leave it connected to the parking pawl. It will hang, not quite enough weight to do any damage, and, if you're a little careful pulling on solenoid you'll be fine and won't have to dick with the eclip up top. Dropping it this way gives you more room to work mostly but keeps it easy to keep everything organized and free from losing.
If the fluid isn't bad I'd suspect
A. Solenoid
B. Wiring going to the PCM
Code sets if the pcm doesn't detect drop in rpm from lockup at all our not quick enough. Myself, I've had that code for nearly 6 years now. Still daily drive it. However, i don't really have lockup either. I know my tcc is pretty much gone.
If you're not getting lockup or it shifts funny/shitty, you'll likely want to replace the tc. I haven't been concerned with mine much as i have a PATC MegaViper sitting in a storage unit for when I'm ready for it lol
__________________
2001 Ram 1500 QCSB, 2" HBS level 285/70/17 Toyo OpenCountry AT2s, M1 2bbl, F&B 52x55mm TB, Pacesetter Longtube headers, 18" Magnaflow, M1 91 Octane canned tune by FlyinRyan, remote start, HS 1.7 RRs, Custom RetroFit 6500K HID, Soon to be boosted...
Old 12-22-2016, 02:30 PM   #5 (permalink)
Engine: Magnum 5.9
Default
Thanks for the safe advice. You're a life saver.
Now I don't have the eclip, phhhw. Do I have to worry about the neutral safety switch like 48re I saw on YouTube
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
air bag code set rustfarmer Tech Info 3 07-21-2016 09:04 PM
P Code?? Jonboy1495 Engine & Performance 4 06-04-2014 09:19 PM
P1404 Code EGR Code bbd90 Engine & Performance 2 02-05-2014 12:31 AM
c code 23 jonathan greene Tech Info 2 02-25-2013 11:11 AM
OBD Code Help Bluesmoke91 Engine & Performance 5 07-19-2011 12:47 PM
GM Truck Forum
Ford Raptor Forum
Chevy Tahoe Forum
Chevy Cobalt Forum
Chevy Camaro Forum
Toyota FJ Cruiser Forum
Ford Truck Forum
88-98 GM Truck Forum
73-87 Gm Truck Forum
Ford Expedition Forum
Chevy Equinox Forum
Chevy Cruze Forum
Jeep Liberty Forum
Jeep Forum
Dodge Ram SRT10 Forum
Chrysler 200 Forum
Scion xD Forum
Scion xB Forum
Dodge Challenger Forum
SRT Forum
Nissan Titan Forum
Buick Enclave Forum
Cadillac Forum
Cadillac XTS Forum
