Hi, I have purchased a dodge ram 1500 pickup. Very clean and the interior is great. My issue is changing to third.
This is a 318 2X4 with a 46RE transmission. I have changed the fluuid and filter. Someone suggested I change a sensor. I see that there are several sensors listed. I would replace these, but I need help. I see the overdrive sensor and the one they spoke of is a TCC pressure sensor and solenoid.
What other ones should I replace. I see the overdrive sensor and the govenor pressure sensor.
Where is the TCC sensor located. The truck doesn't shift into third unless I let off the gas and let the rpm's drop
Thank you for helping me. Am I wasting my time replacing these, or is this a viable repair.
