manuals are great.
the oil in the throttle body is super common. plenum gasket leak. alot of work to fix it.
common issue I have noticed:
-cracked dash
-loose steering (gear box)
-steering clunk (bushing in linkage)
-cup holder design is weak
-heater core leak
-a/c vents change to defrost under hard acceleration of hill climb due to vacuum issue (check valve) this will effect cruise control as well
-plenum gasket leak (upgrade kit cost around $160 and requires removing the intake)
-water pump
