kevin m
New member here first post so be gentle with me. Transmission issue with my 96 5.2 46re put a used trans in as the one in the truck was burnt when I bought it. having overheat issues, replaced ck valve flushed cooler checked for flow thru cooler and back to trans. ok. only thing im thinking now is used trans had a deeper pan on it but it had a hole in it so I put the old pan on in its place do I need the extra oil? I drive less then 10 miles od off light comes on 2 miles more temp light comes on I can smell hot fluid outside the truck.
