Fattywright
- Dec 25, 2015
- 7
- 2
- 2016
- 6.4L Hemi
I have a '97 Cummins 5.9. The truck will start but only runs a couple seconds then stalls. If you roll it again it's the same thing. If you turn the key to the run position the fuel solenoid will open and stay. When you turn the key off the solenoid closes. If you manually open the solenoid and hold it open the truck will run and stay running. It runs good but no tach, no speedometer and the truck will not shift out of high gear unless you manually shift it. The fuse link is good and we replaced the crank sensor. This did not help. If anyone would be able to help it would save the rest of my hair. Thanks for any and all help.
