Go Back   DODGE RAM FORUM - Dodge Truck Forums > Dodge Ram Generations Forum > 2nd Gen : 1994 - 2002 > General Discussion
General Discussion
98 Ram wont start
This is a discussion on 98 Ram wont start within the General Discussion forums, part of the 2nd Gen : 1994 - 2002 category!
Hello all. I have a 98 Ram 1500 5.2 2wd. Was driving the other day just fine and while stopped ...
Reply
Old 12-07-2016, 08:38 PM   #1 (permalink)
Ram Year: 98
Engine: 5.2
Default 98 Ram wont start
Hello all.
Was driving the other day just fine and while stopped at a light, it died on me.....now it just spins over no problem but will not crank.
The fuel pump is sending fuel and when i press the relief on the fuel rail, fuel sprays out.
So im assuming its an ignition problem.
I replaced the plugs, wires, and distrubutor cap and rotor in May. I have not Re-checked the cap and rotor yet.
I replaced the coil today and it still wont start.
Could it be a bad cap or rotor....or a crank sensor? I did a diagnostic and there are no codes.
Any chance it could be the pcm or a ground issue?
Any advice would be appreciated....i gotta get this thing going.
Sponsored Ad
Register to remove this ad.
Fullblast is offline   Reply With Quote
Old 12-07-2016, 10:45 PM   #2 (permalink)
dapepper9's Avatar
Ram Year: 2001
Engine: 5.9L V8
Default
More likely the crank sensor. First double check to make sure there is no spark at the coil wire. If not, go ahead with the crank sensor. Post if you need assistance and updates please
__________________
2001 Ram 1500 QCSB, 2" HBS level 285/70/17 Toyo OpenCountry AT2s, M1 2bbl, F&B 52x55mm TB, Pacesetter Longtube headers, 18" Magnaflow, M1 91 Octane canned tune by FlyinRyan, remote start, HS 1.7 RRs, Custom RetroFit 6500K HID, Soon to be boosted...
Old 12-07-2016, 11:14 PM   #3 (permalink)
GreenClassic's Avatar
Ram Year: 2015 Big Horn CC
Engine: 5.7 Hemi
Default
Same exact thing happened in my 99 Jeep Cherokee. I was driving and it died without any warning. It would crank, but not start. It was the crank position sensor for me.
__________________
Some people just need a high-five.
In the face.
With a shovel.
GreenClassic is offline   Reply With Quote
Old 12-08-2016, 03:37 AM   #4 (permalink)
Ram Year: 98
Engine: 5.2
Default
Where is the crank sensor located? Do i have to remove the starter?
Old 12-08-2016, 08:40 AM   #5 (permalink)
Ram Year: 1998
Engine: Magnum 5.9
Default
Crank sensor is located behind the passenger side head on the bellhousing, google it and there are plenry of diagrams to help you out.
Also check your ASD relay in the fuse block under the hood, i swapped that relat with my AC relay and it fixed a random stall i had.
Max78 is offline   Reply With Quote
Old 12-08-2016, 01:52 PM   #6 (permalink)
dapepper9's Avatar
Ram Year: 2001
Engine: 5.9L V8
Default
Crank sensor is behind the passenger head on the bellhousing like mentioned above and CAN be a pain in the ass. Not hard just hard to reach. Either a 1/2" socket or 1/4" allen key, 2 bolts. That's it
__________________
Old 12-08-2016, 03:15 PM   #7 (permalink)
Ram Year: 98
Engine: 5.2
Default
Ok guys....im going to replace the crank sensor and inspect my fuses and relays....i dont have anybody to help me turn the engine over while i inspect the spark.
Whats the best way to see if the coil is sparking?
How about taking a spark plug thats connected to a wire and holding it against exhaust manifold to see if it sparks?
Old 12-08-2016, 04:11 PM   #8 (permalink)
Ram Year: 1998
Engine: 5.2
Default
The old spark plug trick would work to see if you have spark. Also in my experience even though it is showing pressure at the fuel port doesn't exactly mean it the right/enough pressure it should have to run. Fuel pump could be weak. As in for the crank sensor, did it throw a CEL? If so do you have the capabilities to get a code scanner on it to see what it is throwing? Have the same issues with a customers Ram and it ended up being the ECM out of no where. LMK if I can help or did help.
my98ramquad is offline   Reply With Quote
Old 12-08-2016, 04:53 PM   #9 (permalink)
Ram Year: 98
Engine: 5.2
Default
How do you change this crank sensor? Its a nightmare. I cant get a wrench on it from any position. I got a slight turn on one but thats it.
Do you have to remove the. Transmission dipstick and go from the bottom?
Old 12-08-2016, 04:54 PM   #10 (permalink)
Ram Year: 98
Engine: 5.2
Default
I have a code scanner and its showing theres no codes at all.
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
R/T wont start !! La sinco siete Engine & Performance 13 12-09-2015 12:07 PM
Replaced head gaskets, but now wont start with out pressing throttle. wont idle instyle Engine & Performance 2 10-23-2015 07:50 PM
08 6.7 Wont start!! hall_jerry 6.7 Common Rail 1 09-17-2014 06:01 PM
Need help truck wont start and tuner wont work!!! Razzaa Engine & Performance 33 01-13-2014 06:08 PM
Ran Out Of Gas---Wont Start Now cstroy86 Engine & Performance 8 10-24-2012 11:59 AM
GM Truck Forum
Ford Raptor Forum
Chevy Tahoe Forum
Chevy Cobalt Forum
Chevy Camaro Forum
Toyota FJ Cruiser Forum
Ford Truck Forum
88-98 GM Truck Forum
73-87 Gm Truck Forum
Ford Expedition Forum
Chevy Equinox Forum
Chevy Cruze Forum
Jeep Liberty Forum
Jeep Forum
Dodge Ram SRT10 Forum
Chrysler 200 Forum
Scion xD Forum
Scion xB Forum
Dodge Challenger Forum
SRT Forum
Nissan Titan Forum
Buick Enclave Forum
Cadillac Forum
Cadillac XTS Forum
