Go Back   DODGE RAM FORUM - Dodge Truck Forums > Dodge Ram Generations Forum > 2nd Gen : 1994 - 2002 > General Discussion
Sponsored Ads
Register to remove these ads.
General Discussion
a/c bypass?
This is a discussion on a/c bypass? within the General Discussion forums, part of the 2nd Gen : 1994 - 2002 category!
Register to remove these ads. It's free! So my latest ?? When I hit the gas to pass, or when ...
Reply
Old 02-06-2012, 04:24 PM   #1 (permalink)
Ram Year: 1997
Engine: Magnum 5.9
Default a/c bypass?
So my latest ??
When I hit the gas to pass, or when I'm towing any kind of load, uphill..yada...the a/c or heat will transfer to the defrost vents...anyone elses trucks do this?
RobS is offline   Reply With Quote
Old 02-06-2012, 09:15 PM   #2 (permalink)
bigbadram1500's Avatar
3rd Gen / Site Mod
Ram Year: 2008
Engine: Hemi 5.7
Send a message via Yahoo to bigbadram1500
Default
Bump for ya. Sounds like maybe a vacuum issue.
__________________
RamForum.com Moderator
2008 Ram 1500 QC SB 4x4 Hemi in Sunburst Orange
SC3815, BFI, Power Wire, 2.5" Ready Lift Leveling Kit, 34" Nitto TG's, 8k Bi-Xenon Direct Fit Projectors, 6k Fogs, LED Tails, 6k Hellas behind the grill, BakFlip G2, BedRug, Wheel Well Liners, Debadged, Flowmaster 40 Exhaust, Kicker 12" CVR in Custom Console, Kicker 400.1 amp, OEM Tow Mirrors
bigbadram1500 is offline   Reply With Quote
Old 02-08-2012, 09:51 AM   #3 (permalink)
rambob's Avatar
Ram Year: 2001
Engine: 318 5.2l
Default
mine does it also.
I read some stuff about replacing the check valves (vacuum)
they are only about $5 from the dealer.
I replaced the two I have and it didnt fix the problem.
ut yes, from what I understand. its all vacuum related.
and if you have cruise control, it affects it as well.
__________________
2001 RAM, 5.2l, 5" LIFT, 33" BFGs, 100 wt yellow fogs, all base model
rambob is offline   Reply With Quote
Old 02-08-2012, 10:45 AM   #4 (permalink)
rambob's Avatar
Ram Year: 2001
Engine: 318 5.2l
Default
I think I may have a vacuum leak somewhere.
I read the plenum gasket leak may contribute to it as well.
__________________
Old 02-08-2012, 05:22 PM   #5 (permalink)
Ram Year: 1997
Engine: Magnum 5.9
Default
i dont think the plenum is leaking, i looked all around it, and down under the throttle body...no oil or anything, like ive read you'd see...i'd hate to pull it off and find out it wasn't the problem...as far as the vaccuum line, which ones did you replace? under the dash or elsewhere...i'd rather start with that first...
Old 02-08-2012, 05:36 PM   #6 (permalink)
rambob's Avatar
Ram Year: 2001
Engine: 318 5.2l
Default
two check valves
part # for the check valves is 4549209
pass side right near thottle body - on the line going into the vavle cover or around there.
the 2nd is on the pass side up near the fire wall.
__________________
Old 02-08-2012, 05:38 PM   #7 (permalink)
rambob's Avatar
Ram Year: 2001
Engine: 318 5.2l
Default
be super careful with the vacuum lines.
soo many people have broken them - they are old and brittle.
the easiest way for me was to pull the entire part hose out of the engine near the TB, and then cut a slit with a knife. pull the CV out, and trim the hose back to a good part past the slit, then push the new CV on and re install.
the small diameter hose are even easier to break. luckily, the washer hose is a good fit over them.
__________________
Old 02-08-2012, 05:42 PM   #8 (permalink)
rambob's Avatar
Ram Year: 2001
Engine: 318 5.2l
Default
google "wild vents" and you will see plenty of info.
but what I have told you is the most common fix
good luck
__________________
Old 02-09-2012, 09:25 AM   #9 (permalink)
Ram Year: 1997
Engine: Magnum 5.9
Default
ill look into it today, Thanks Ram!!
Old 02-15-2012, 11:27 AM   #10 (permalink)
Ram Year: 1996 & 2001
Engine: V-10 and 5.9 diesel
Default
Did anyone come up with a solution. My '96 V-10 has been doing something similar for years. Putting any kind of strain on it, like going up a hill, the a/c jumps over to the defrost and blows warm air. Not a big deal but it is annoying. So far I haven't found any vaccuum leaks.
kslongrider is offline   Reply With Quote
Reply
Bookmarks
Tags
a/c transfer, air issues, vacuum issues
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Dual Bypass Setup for 2011 Hemi. WhiteExpress Amsoil 13 09-26-2011 10:13 AM
In-Dash DVD Video Bypass Procedures NOTW Audio & Electronics 11 07-07-2011 10:58 AM
DIY: Heater Core Bypass RubberFrog 3rd Gen DIY 6 11-12-2010 12:58 AM
Fully Driven Auto Network
GM Truck Forum
Ford Raptor Forum
Chevy Tahoe Forum
Chevy Cobalt Forum
Chevy Camaro Forum
Toyota FJ Cruiser Forum
Ford Truck Forum
88-98 GM Truck Forum
73-87 Gm Truck Forum
Ford Expedition Forum
Chevy Equinox Forum
Chevy Cruze Forum
Jeep Liberty Forum
Jeep Forum
Dodge Ram SRT10 Forum
Chrysler 200 Forum
Scion xD Forum
Scion xB Forum
Dodge Challenger Forum
SRT Forum
Nissan Titan Forum
Buick Enclave Forum
Cadillac Forum
Cadillac XTS Forum
