Christmas Eve and my truck decides to die on me...
kdryan
So yeah... My '98 Ram 1500 Sport with a 5.2 which has run faithfully all year long decided to die on me on Christmas Eve of all times.
It has been taking a bit longer to start than I like but I put that down to the cold here. Driving home, it suddenly started losing power, gained it back and lost it a few more times before the engine quit for good. I am getting spark to the coil and when I sprayed starting fluid into the air cleaner for a few seconds it ran then died.
So I am guessing fuel pump?
MADDOG
Not RamForum Staff
Fuel pump, fuel filter or an evap/vacuum leak at the intake manifold would be my guess.
One other thing...how cold is it where you are?
kdryan
kdryan
Mid-30's at best...
Gr8bawana
6.7 CTD
It sounds like the fuel pump.
dudeman2009
Magnum 360
I'd guess fuel pump. You can try a fuel pressure test to see if anything weird shows up.
