Go Back   DODGE RAM FORUM - Dodge Truck Forums > Dodge Ram Generations Forum > 2nd Gen : 1994 - 2002 > General Discussion
General Discussion
correct used Transmission ?
This is a discussion on correct used Transmission ? within the General Discussion forums, part of the 2nd Gen : 1994 - 2002 category!
I own a 96 ram 1500 4x4 with a 5.9 v8 and the transmission died . I cannot afford a ...
Reply
Old 01-03-2017, 03:01 PM   #1 (permalink)
Ram Year: 1996 1500 4x4
Engine: 5.9 v8
Default correct used Transmission ?
I own a 96 ram 1500 4x4 with a 5.9 v8 and the transmission died . I cannot afford a 2000.00 rebuild so I found a low millage one for sale out of a 99 4x4 also with a 5.9 v8 are these transmissions the same? 46re? any changes for those years or direct bolt up? Thanks for the help
Sponsored Ad
Register to remove this ad.
badluck is offline   Reply With Quote
Old 01-03-2017, 03:50 PM   #2 (permalink)
Ram Year: 2001 1500 Sport with 3/4 ton spring pack
Engine: Magnum 318
Default
The transmissions are the same, but you will want to wait for Dapepper to speak on which flexplate/torque converter to use.
I'm pretty sure that you can use the flexplate and torque converter from your current engine on the newer trans, but I can never remember with 100% certainty.
I'd also look at installing a secondary oil cooler if your truck doesn't have it already.
Old 01-03-2017, 05:09 PM   #3 (permalink)
Engine: 5.9 v8
Default that works
Thank you sounds good. Is 400.00 a good price and would you change all the Sensors now after I purchase it?
Old 01-03-2017, 05:30 PM   #4 (permalink)
Engine: Magnum 318
Default
It depends on how many miles are on it. If you don't feel like rebuilding it, try for something that has already been rebuilt, or has less than 80K miles, otherwise you're just spinning the wheel.
If you don't mind rebuilding it yourself, you can get complete rebuild kits for anywhere from $300-500 that cover most problem areas.
If its been rebuilt, 400 is a good price as long as nothing looks burnt. If not, I wouldn't pay more than 300 because that means i'm going to have to spend that again to rebuild it.
Old 01-04-2017, 09:56 AM   #5 (permalink)
dapepper9's Avatar
Ram Year: 2001
Engine: 5.9L V8
Default
Yep 96+ the tq converter is the same between the 5.2 and 5.9 but the flexplate is different. Being as both are 5.9 you shouldn't have issues there.
To work in a 96 you'll need the 96-97 governor solenoid and sensor as well as tcc/od solenoid. The big issue you'll run into is the vehicle speed sensor. After 98, it was moved to the rear axle so the 99 has no place for it. Luckily, it's not actually in the trans but the transfer case. Use your 96 transfer case and you'll be fine, swapping tcases is just a little more work.
This is a good kit to use top get everything you'll need covered.
A518 / 46RE Master Solenoid Service Kit 1995 Thru 1997 Models - With 8 Pin Harness
400 is a good price if it's in working order and another 200 for the service kit you're sitting pretty good if you can do the work. If you can spend the extra scratch, a transfer case saver kit is also a good idea
NP231,NP241,Np243 Transfer case saver, don't leave home without it, DIY and save money! - Drivetrain
__________________
2001 Ram 1500 QCSB, 265/75/16 ProComp MT2s, M1 2bbl, F&B 52x55mm TB, JBA Stainless Shorty Headers, Carven R Series, M1 91 Octane canned tune by FlyinRyan, remote start, HS 1.7 RRs, Custom RetroFit 6500K HID, Soon to be boosted...
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Transmission ID & Correct Rebuild Kit Maven1 Tech Info 1 05-13-2016 09:48 PM
is this correct? ralaubach Exterior 3 10-31-2014 02:13 PM
Correct oil weight DDean Engine & Performance 1 04-12-2014 08:23 PM
Is this the correct Y pipe JoeyDBabe Engine & Performance 3 05-29-2013 04:54 AM
What's the correct hub size? Mudder Exterior 4 03-07-2013 09:27 PM
GM Truck Forum
Ford Raptor Forum
Chevy Tahoe Forum
Chevy Cobalt Forum
Chevy Camaro Forum
Toyota FJ Cruiser Forum
Ford Truck Forum
88-98 GM Truck Forum
73-87 Gm Truck Forum
Ford Expedition Forum
Chevy Equinox Forum
Chevy Cruze Forum
Jeep Liberty Forum
Jeep Forum
Dodge Ram SRT10 Forum
Chrysler 200 Forum
Scion xD Forum
Scion xB Forum
Dodge Challenger Forum
SRT Forum
Nissan Titan Forum
Buick Enclave Forum
Cadillac Forum
Cadillac XTS Forum
