I've searched forums and searched to try to fix my truck......
So here I go, ill tell you my truck's history since day 1.
Truck is a 5.2 (318) 5spd single cab, 4x4 of course.
This is what the truck had on it when I bought it.
35" Super Swampers
Steel 16" wheels (Don't know what kind and how wide)
Skyjacker 3" lift
3" Body lift
Also came with a set of 285s (I think)
When I bought the truck I was told it needed to have alignment done a new seal for the front axle, but the guy told me I could drive it up the road just really quick, (this had the 35s on it at the time) so me and my brother drove it up the road everything went fine it had no death wobble. So I took it back and told the guy I wanted the truck, we loaded it up on the rollback and headed home. When I got it home I wanted to drive it up the road again just really quick and it still had no death wobble, after I got back to the house I parked it until I could get it to the shop. Well when I got it to the shop the guy looked at it and said the axle was bent and there was know reason to replace the seal even tho I done bought the seal, so now I was stuck having to buy a used axle from the pull a part, got the axle on new seals put in drove it up the road and that's when the death wobble started, still had the 35s on it same lift nothing changed. So then I was told to take off the 35s and put the 285s on (only if you could have seen what the truck looked like with 285's with a 3" body lift and 3" lift kit HAHA) but anyways I didnt want to get the truck alignment done till i bought new tires for it because you could tell it needed alignment done big time the front wheels was toed in so bad but the weird thing about that is with it being like that and with the 285s on it, It never did do the death wobble......
Now truck has.
305s
16x10 black rock steel wheels
3" Skyjacker lift
So later on down the road I had the money saved up to get new wheels, new tires, new tie rods, and new ball joints. At this time the 3" body lift is off, tires are now 305s, wheels are blackrock steel wheels 16" x10, all the ball joints are on but had to tac weld one to stay on because it kept wanting to pop out and also got the truck alignment done but they didnt put the new tie rods on even tho they said they needed them. But still has the death wobble thinking all of this would help this solve the problem.
So now I'm asking for some help from you all I've been without my truck for 5months now and I'm in need of it since i just wrecked my car a month ago and rolled it 3 times. Plus I'm having a kid coming in 4 weeks, so I really need my truck. Ive researched on forums and haven't really had any luck. If anybody can tell me what I need to get or explain to me what to do I would really appreciate it. Sorry for the long story but I figured I would explain it all since day 1.
Also would like some help on my 4wd. When I put my truck in 4wd it feels like something is in a bind, the front of the truck wants to sway back and worth, could this be because the death wobble?? Do I need something new?
Thank you.
35" Super Swampers
Skyjacker 3" lift
3" Body lift
Now truck has.
305s
3" Skyjacker lift
Thank you.
