regularcab2500
Hello all!
So i found out my truck has a 241HD transfer case that was bastardized to fit the 46re in my truck. Long story short the guy i bought it off of didnt want to put the money into finding the correct tcase when he broke the original so the guy he bought it from (who owns the shop that performed the swap and is the original owner's son) did as cheap of a job as he could so the kid didn't scrap the thing. Right now, the shift mechanism is a hokey twist knob with a cable to engage the axle bolted properly to the back of the axle shaft where normally the vacuum actuator set up would be. The manual shifter on the floor is hooked up but low range does not engage and the shifter wont even go into postition. I would like to set this back up to the factory system but my concern is whether or not i can make the 241hd function in that way. As much as ive been learning the past year about rebuilding axles and engines, ive never bothered to learn about transfer cases or the corresponding axle disconnect systems as its never been a concern.
Another option would be to acquire an original tcase and front driveshaft for the truck but im having difficulty determining the differences between the np241 and np241d if there is one.
OR...if someone could get me the number off of their 94-97 ram 2500 4x4 auto with 360 gas i would appreciate it because i think i could figure it out from there.
UPDATE: I did figure out the tag number for the original tcase based on a part number that the dealership gave me..it was missing a zero and was screwing me up so i have some more numbers to cross reference now but if any one has any answers about keeping the 241hd that would be splendid
