haroldsworld66
- Jan 2, 2013
- 1
- 0
- 2000
- 5.2 L
i have a 2000 dodge ram 1500 5.2 L i had a drivers side front axle leak when i took it apart i found lots of play in the u joints so i replaced them but my problem is i cant seem to get the pinion gears out [pin is behind the big crown gear ] or i cant seem to get the whole carrier out [ not sure if proper terms i slid the intermediate shaft back and both axles are out but i cant seem to get the rest out in order to replace the seal any suggestions would be helpful thank you
