Go Back   DODGE RAM FORUM - Dodge Truck Forums > Dodge Ram Generations Forum > 2nd Gen : 1994 - 2002 > General Discussion
General Discussion
Front end sqeeking
This is a discussion on Front end sqeeking within the General Discussion forums, part of the 2nd Gen : 1994 - 2002 category!
I noticed the other day finally got warm enough to roll window down and I noticed a sqeeling from the ...
Reply
Old 02-18-2014, 02:12 PM   #1 (permalink)
jonwalden68's Avatar
Ram Year: 1999
Engine: 5.2
Default Front end sqeeking
I noticed the other day finally got warm enough to roll window down and I noticed a sqeeling from the front sounds like driver side it does it whole time while driving it sounds like brakes but hitting the brakes doesn't affect the sound or make noise worse any idea? I don't wanna replace brakes if it's not it just don't know what else
Sponsored Ad
Register to remove this ad.
__________________
1998 Dodge Ram 4x4 5.2 V8
jonwalden68 is offline   Reply With Quote
Old 02-18-2014, 02:35 PM   #2 (permalink)
Ram Year: truck
Engine: gas
Default
It could be the Unit bearing/wheel bearing is on it's way out. Jack the truck up on that side grab the tire and see if it has any side to side or top to bottom movement in it.
Merc225hp is offline   Reply With Quote
Old 02-18-2014, 02:50 PM   #3 (permalink)
Ram Year: 1999
Engine: 5.2
Default
I know there is some play. Side to side but I was gonna wait till
I could afford to buy both till I replaced. I was wondering if the brakes could just be rubbing rotor constantly and sqeeking but seems like it would get worse when I hit brakes or stop the noise one
__________________
Old 02-18-2014, 02:54 PM   #4 (permalink)
NYCruiser's Avatar
Ram Year: 2014
Engine: Hemi 5.7
Default
If it doesn't change with the brake pedal, it isn't the brakes. Sorry.
NYCruiser is offline   Reply With Quote
Old 02-18-2014, 03:03 PM   #5 (permalink)
Ram Year: 1999
Engine: 5.2
Default
Are the bearing on the 4wd press in or bolt on? Trying to figure if I can do it myself
__________________
Old 02-18-2014, 04:30 PM   #6 (permalink)
Ram Year: 1999
Engine: 5.2
Default
Took off the wheel brakes and rotors good. Hub is bad, needs upper ball joint. Can you replace the u joint on axle shaft? And what is the bearing or seal called were the axle shaft goes into axle
__________________
Old 02-26-2014, 11:13 AM   #7 (permalink)
Bigtman07's Avatar
Registered User
Ram Year: 1998/2000
Engine: Magnum 5.9/Cummins 5.9
Send a message via Yahoo to Bigtman07
Default
The Hub and bearing is all in one unit. If you have All Wheel ABS its not a cheap part. The axle u joint is replaceable along with the ball joint.
__________________
Never Apologize for being Patriotic! 'EM Join Hunter nation! RF Hunt Club!
"If he's gonna put his lips on something I made I'd rather it be a duck call." ~Willie Robertson
New Here? Introduce yourself here - Click here to become a Supporting Member - Check out our Preferred Vendors!
Bigtman07 is offline   Reply With Quote
Reply
Tags
front end noise, hub bearing, sqeaking, squealing front
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Front pinion bearing gone. How hard to remove front diff? Caustic Tech Info 2 09-09-2013 07:12 PM
Which front is this? CokeZero Exterior 6 06-24-2013 04:27 PM
front end vib around 65-70 mph rambob Lifted 2 04-13-2012 08:59 PM
front end help rambob Lifted 5 08-28-2011 05:35 PM
2500 HD Front Bumper Vs 1500 Front Question SafetyGuy General Discussions 7 10-21-2010 12:51 PM
GM Truck Forum
Ford Raptor Forum
Chevy Tahoe Forum
Chevy Cobalt Forum
Chevy Camaro Forum
Toyota FJ Cruiser Forum
Ford Truck Forum
88-98 GM Truck Forum
73-87 Gm Truck Forum
Ford Expedition Forum
Chevy Equinox Forum
Chevy Cruze Forum
Jeep Liberty Forum
Jeep Forum
Dodge Ram SRT10 Forum
Chrysler 200 Forum
Scion xD Forum
Scion xB Forum
Dodge Challenger Forum
SRT Forum
Nissan Titan Forum
Buick Enclave Forum
Cadillac Forum
Cadillac XTS Forum
