meistermash
Friends, I have been trying to get my stock 01 1500, to go down the road with out my looking like I just left the bar.
I just did the ball joints, both sides, adjusted the steering box, and added one of those braces to the bottom of the steering box to eliminate play there. Also did the hubs and axel joints while it was apart. There was a bunch of play in the bottom of the steering box prior to adding the brace.
It has helped out immensely.
I did not see any play in the other components or if there is I can't see it.
My question is, I still have a small bit of weirdness going on.
I know that I need to have it aligned.
I should replace the steering box for one thing but adjusting it has fixed most of that along with the brace.
What am I over looking?
Tie rod ends seemed to be tight.
