Jimmy68
- Aug 30, 2015
- 1,419
- 645
- Lethbridge Alberta Canada
- 2001
- 5.2L Magnum
I found Front is a Dana 60 with 1.5 ".250wall tie rod and draglink with offset GM 1ton taper tie rod ends and a north west fab freddilink above knuckle, trackbar mount has a weld washer to eliminate ovalizing the hole, has bds lift brackets, extended brake lines, brakes are 85%, CAD unit is permanently engaged, and the Pitman arm for the different taper tie rod end. Bds control arms.
Rear is a Dana 70 with posi, good working drums, 1410 yoke. Also have a 14bff with disc brakes in the deal.
All diffs are 4:10 all work good and a 6" BDS suspension lift.
$1400. Good deal or what?
