Go Back   DODGE RAM FORUM - Dodge Truck Forums > Dodge Ram Generations Forum > 2nd Gen : 1994 - 2002 > General Discussion
General Discussion
Help!!!
This is a discussion on Help!!! within the General Discussion forums, part of the 2nd Gen : 1994 - 2002 category!
Please help my truck won't run no spark if I can't get her running gf said it has to go ...
Reply
Old 12-29-2016, 09:42 PM   #1 (permalink)
Ram1500318v8's Avatar
Ram Year: 1998
Engine: Magnum v8 5.2 318
Default Help!!!
Please help my truck won't run no spark if I can't get her running gf said it has to go I have a 98 ram 1500 318 v8 no spark tried crank sensor distributor new computer and a new battery nothing worked help please check gage light on
Sponsored Ad
Register to remove this ad.
Ram1500318v8 is offline   Reply With Quote
Old 12-30-2016, 08:51 AM   #2 (permalink)
dapepper9's Avatar
Ram Year: 2001
Engine: 5.9L V8
Default
What's the code it's throwing? Seeing as you changed the distributor you made life much more difficult. These trucks timing can't be set Ruth a light, pcm sets it. Pulling the distributor fucks the fuel sync though. Need to follow the distributor procedure in the factory service manual which can be downloaded from the site. That'll get you close enough to drive without any real issues.
As for your no spark, you've tried crank sensor which is a good place to start and pcm which is really the last thing lol. Does it crank fine? Might look at the cam pickup plate in the distributor and ohm check the coil to make sure it's not bad.
__________________
2001 Ram 1500 QCSB, 2" HBS level 285/70/17 Toyo OpenCountry AT2s, M1 2bbl, F&B 52x55mm TB, Pacesetter Longtube headers, CarvenTR, M1 91 Octane canned tune by FlyinRyan, 4.56 gears+Eaton TrueTrack remote start, HS 1.7 RRs, Custom RetroFit 6500K HID
Old 12-30-2016, 09:44 AM   #3 (permalink)
Ram Year: 2014
Engine: 5.7 Hemi
Default
Does it turn over really fast? Have you done a compression check? Really fast turn over and no spark generally =s timing chain broken or distributor incorrectly seated on the cam gear
__________________
Truckless for now. Dually in my future 😜
12sportmc is offline   Reply With Quote
Old 12-30-2016, 08:25 PM   #4 (permalink)
Yeret's Avatar
Location: Under the hood, trying to find that ****ing bolt that I dropped...
Ram Year: 1999
Engine: 5.9 Magnum
Default
I second ohm-checking the ignition coil. You'll need a multimeter but testing the coil is very easy. If you're unlucky like me and the bolts between it and the mounting bracket are rust-welded, you'll have to remove it with the mounting bracket. One of the bracket bolts also passes through the belt tensioner, so you may have to remove the belt to relieve the pressure. Fortunately, the drive belt is super easy to remove on our trucks. You'll need a minimum 3/8 drive ratchet and I think a 15mm socket.
This page explains how to test the coil and what your readings should be. Good luck.
PS: If your woman isn't mechanically inclined and she wants the truck gone but you don't, just throw her a BS answer that the problem is simple and cheap to fix and you have mail-ordered a part, but will take a week to arrive. Worst case scenario if you don't have the truck running by then, just say that something else came up. What you do then will be up to you however. Women have patience if they don't know any better but are completely unyielding once they lose it, LOL.
__________________
1999 Dodge Ram 1500 4x4 SLT Laramie
The only true screw-up is one that can't be reversed!
American Racing Nitro, K&N open element, modified 50mm, eBay shorties, 2.25" y-pipe, Magnaflow cat, Cherry Bomb Extreme, DUI LiveWires/cap/rotor, canned 91 tune by Flyin' Ryan, Hughes plenum repair, 4x4 Posi-Lok, on-board Money Sink 3000
Yeret is offline   Reply With Quote
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
GM Truck Forum
Ford Raptor Forum
Chevy Tahoe Forum
Chevy Cobalt Forum
Chevy Camaro Forum
Toyota FJ Cruiser Forum
Ford Truck Forum
88-98 GM Truck Forum
73-87 Gm Truck Forum
Ford Expedition Forum
Chevy Equinox Forum
Chevy Cruze Forum
Jeep Liberty Forum
Jeep Forum
Dodge Ram SRT10 Forum
Chrysler 200 Forum
Scion xD Forum
Scion xB Forum
Dodge Challenger Forum
SRT Forum
Nissan Titan Forum
Buick Enclave Forum
Cadillac Forum
Cadillac XTS Forum
