This is my friend's 97 1500 4x4 with a 5.9. Mileage is actually pretty low; around 150k. This problem has us stumped and I'm starting to obsess about it...
My buddy's truck developed a problem where the brake lights would stay on all the time. He uses it so rarely and short local trips so he never thought about fixing it till a few weeks ago.
We thought it was a bad brake switch... but no.
Come to find out the brakes were 'soft' and the brake pedal seemed to be riding too low. I assumed worn out brakes.
So we did a brake job all the way around... New rotors, calipers, and hoses on the fronts. New cylinders, shoes, drums and hardware on the rears.
Bled the brakes, adjusted the rears and tested.
Didn't help.
The brakes were better for sure so now when the pedal rode low the brakes actually drag. If you took your foot off the gas it would now stop the truck eventually. If you lifted the pedal with your toe the pedal would stay put and the brakes don't drag but as soon as you brake again the pedal will not come all the way up on its own.
Bled them a couple of more times with no change.
We then changed out the master cylinder and the brake booster. There seemed to be a little fluid between them, like slightly damp. And of course some grime. But if there was a leak it wasn't much of a leak.
It didn't cure the problem.
We've bled the ABS at least 15 times thinking that we got a little air in when we connected the lines to the master cylinder.
No change, pedal still wants to stay down a little and the brakes drag.
I pinched off the vacuum line to the booster with some vise grips and now the pedal comes up.
So too much vacuum? I've not measured the vacuum with a gauge but it 'feels' about right for manifold vacuum.
But since pinching the line doesn't actually reduce vacuum... more like volume it seems to me, eventually, if you drive it very long, it will start to drag again.
I keep thinking we still have air in the abs, rwal valve or the combination valve because when idling, for instance at a stop sign, if I pump the brakes 3-4 times the pedal comes up and stays up.
But I've bled them a bunch of times and when the trucks not running the brakes are hard and the pedal stays up.
Like I said I'm outa ideas.
Didn't help.
