Go Back   DODGE RAM FORUM - Dodge Truck Forums > Dodge Ram Generations Forum > 2nd Gen : 1994 - 2002 > General Discussion
General Discussion
HELP! Transfer case failure????
This is a discussion on HELP! Transfer case failure???? within the General Discussion forums, part of the 2nd Gen : 1994 - 2002 category!
I was sitting in stopped traffic on a street and as I hit the gas to move, I heard a ...
Reply
Old 09-30-2016, 08:49 PM   #1 (permalink)
05ram4x4's Avatar
Ram Year: 2002 Ram 2500 4x4 Quad cab
Engine: 5.9 Magnum
Default HELP! Transfer case failure????
I was sitting in stopped traffic on a street and as I hit the gas to move, I heard a loud sound and then nothing but grinding. As I hit the gas the grinding got louder. Truck wouldn't move under power at all. Luckily I was moving enough to roll to the side of the road. I wonder if my chain snapped in the transfer case...but I thought it was a direct connection through it to the rear axle. I had an issue with the rear of my overdrive unit breaking off and the transfer case sitting on my skid plate for a while. Could the splines of just worn off over time and finally given up? That's the grinding sound I hear? I'm going to try and pull the transfer case tomorrow and take a look. Also, is replacing the overdrive unit as easy as pulling off another one and sliding it on my transmission? Kinda amazes me that the transfer case doesn't get any support other than being bolted to the transmission.
Any thoughts are appreciated!
Sponsored Ad
Register to remove this ad.
05ram4x4 is offline   Reply With Quote
Old 09-30-2016, 11:38 PM   #2 (permalink)
Ram Year: 2001 1500 Sport with enough electrical modifications to make your head spin
Engine: Magnum 360
Default
I'm not going to stab at what is grinding, there is a lot of things that can grind. Any splined shaft can. Your transfer case is likely fine, the chain is attached to a dog clutch, its disengaged when in 2wd. Yes the input of the transfercase is directly connected to the rear output.
It is a ford, but my buddies dad had his truck do the exact same thing, he shattered a gear on output shaft and it was grinding on the countershaft gear. I've seen fords with damaged rear axle bolts where the transmission output yoke slipped out enough to bind and grind on the splined output shaft.
It could be from anywhere down there really, the only way to find out for sure is to take it apart. You can drop the pan on the tranny to see if there are broken pieces in it.
Old 09-30-2016, 11:43 PM   #3 (permalink)
05ram4x4's Avatar
Engine: 5.9 Magnum
Default
I will have to start tearing it apart tomorrow and see what I find. Thanks for the input.
Old 12-18-2016, 08:46 PM   #4 (permalink)
05ram4x4's Avatar
Engine: 5.9 Magnum
Default
I know this is older now, but the grinding was because the transfer case wasn't sitting straight on the output shaft of the transmission, which resulted in the input splines smoothing off.
When I pulled the overdrive unit and transfer case, i put them together on the ground and I could cause the transfer case to slip on the overdrive unit with only hand pressure.
Old 12-19-2016, 12:24 AM   #5 (permalink)
Engine: Magnum 360
Default
That would do it. Thanks for coming back with that. I think its odd that the Tcase was off like that, but I guess there are plenty of ways it could have occurred.
Old 12-20-2016, 08:23 PM   #6 (permalink)
05ram4x4's Avatar
Engine: 5.9 Magnum
Default
It was sitting like that because the flange on the overdrive unit snapped off. That's why I replaced both.
Sent from my SM-G935T using Tapatalk
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Transfer case JMikk General Discussion 0 03-26-2016 02:51 PM
transfer case? 03hemi55060 Engine & Performance 0 04-18-2014 10:57 AM
Transfer case 94 Tlee1214 Tech Info 1 03-12-2014 12:03 PM
transfer case markat Tech Info 1 08-20-2012 11:06 AM
Transfer Case Help!!! iSlacker816 Engine & Performance 7 02-13-2012 08:13 PM
GM Truck Forum
Ford Raptor Forum
Chevy Tahoe Forum
Chevy Cobalt Forum
Chevy Camaro Forum
Toyota FJ Cruiser Forum
Ford Truck Forum
88-98 GM Truck Forum
73-87 Gm Truck Forum
Ford Expedition Forum
Chevy Equinox Forum
Chevy Cruze Forum
Jeep Liberty Forum
Jeep Forum
Dodge Ram SRT10 Forum
Chrysler 200 Forum
Scion xD Forum
Scion xB Forum
Dodge Challenger Forum
SRT Forum
Nissan Titan Forum
Buick Enclave Forum
Cadillac Forum
Cadillac XTS Forum
