dudeman2009
- Feb 9, 2016
- 1,562
- 208
- Arizona
- 2001 1500 Sport with enough electrical modifications to make my brain hurt
- Magnum 360
I'm stumped at this point, i've tried all that I can think of minus one thing. Last week Wednesday I got home and locked my truck like normal,, it chirped the horn in confirmation. I let it sit till Sunday morning when I went to grab some stuff out of it, only when I hit the lock button, no chirp. The only thing that happened to the truck since it was last working is Sunday morning I decided to play with the key in the lock cylinder to try and get the other side to unlock. All I did was flip the key around from lock to unlock trying a couple different patterns. Also, the panic button no longer works. I've verified the horn works from they horn relay on down by depressing the horn.
The only thing I haven't done yet is remove the door panel to inspect the back of the lock cylinder. Other than that, I've checked both door ajar switches, pulled every relevant fuse to check including IOD, verified that both door lock switches and lock solenoids work, as well as ensuring neither connector on the CTM was loose.
I just remembered that I haven't tried disconnecting the battery yet, i'll try that this Friday or Saturday before I remove the door panel (I really want to know if I have the hardware for central unlocking as i'm considering putting in a security system my buddy has some experience with).
Any ideas are appreciated.
