Go Back   DODGE RAM FORUM - Dodge Truck Forums > Dodge Ram Generations Forum > 2nd Gen : 1994 - 2002 > General Discussion
General Discussion
Horrible Squealing! Need Help!
This is a discussion on Horrible Squealing! Need Help! within the General Discussion forums, part of the 2nd Gen : 1994 - 2002 category!
For the last month or so my truck has been making a massive squealing (like wake the neighbors loud) from ...
Reply
Old 11-24-2016, 03:26 AM   #1 (permalink)
AshleyR063's Avatar
Ram Year: 1997
Engine: 5.2 318
Default Horrible Squealing! Need Help!
For the last month or so my truck has been making a massive squealing (like wake the neighbors loud) from under the hood. I've replaced the tensioner, idler pulley, alternator, and I'm routed around my A/C compressor pulley with a shorter belt. While the truck is off I can spin the fan freely, no friction or noise. Would the crank shaft pulley/harmonic balancer cause this? I'm at a loss, it's driving me crazy. Any suggestions are appreciated. Thanks in advance.
Sponsored Ad
Register to remove this ad.
AshleyR063 is offline   Reply With Quote
Old 11-25-2016, 11:09 PM   #2 (permalink)
DodgeTx's Avatar
Ram Year: 2000
Engine: 5.9L
Send a message via Skype™ to DodgeTx
Default
did you replace the belt? try maybe to grease the belt? something is causing to much tension causing it to make noise.
I had a ford taurus a year or so ago that the alternator bearing was going out, but I put some grease on the belt every other day and it stayed quiet until I sold it.
DodgeTx is offline   Reply With Quote
Old 11-26-2016, 12:23 AM   #3 (permalink)
dapepper9's Avatar
Ram Year: 2001
Engine: 5.9L V8
Default
Start spraying pulleys with silicone spray or wd40 with it running until the problematic one quiets. My bet is power steering pump
__________________
2001 Ram 1500 QCSB, 2" HBS level 285/70/17 Toyo OpenCountry AT2s, M1 2bbl, F&B 52x55mm TB, Pacesetter Longtube headers, 18" Magnaflow, M1 91 Octane canned tune by FlyinRyan, remote start, HS 1.7 RRs, Custom RetroFit 6500K HID
Old 11-26-2016, 11:43 PM   #4 (permalink)
Marksman's Avatar
Ram Year: 1999 Ram 2500 4x4 SLT
Engine: V10
Default
When you have the belt off, how does the alternator feel/sound when you spin it? I doubt it has one, but if it does have California emissions, it might have an air pump. Spin it too. In fact, do this with everything that rotates. Water pump, power steering, etc.
Has your steering effort changed any? Check the fluid in the power steering pump. Also follow what has been said above about using WD-40.
Marksman is offline   Reply With Quote
Old 11-27-2016, 11:41 PM   #5 (permalink)
Ram Year: 2001 ram 3500
Engine: V10
Default
are you losing any coolant? My jeep was doing that on start up for a day or two, until I realized coolant was wetting the belt, making it slip and squeal.
Rustycowl69 is offline   Reply With Quote
Reply
Bookmarks
Tags
2nd gen 4x4, pulley noises, squealing
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
squealing belt outdoorram Engine & Performance 9 10-28-2015 03:49 AM
Squealing bassslayer25 General Discussion 10 06-13-2015 10:49 PM
Alternator squealing Adamc23 Engine & Performance 9 09-06-2014 09:42 PM
Squealing noise Johnnyv87 Tech Info 4 03-20-2014 08:38 PM
Squealing sound TexasRammer General Discussions 15 02-26-2014 12:48 AM
GM Truck Forum
Ford Raptor Forum
Chevy Tahoe Forum
Chevy Cobalt Forum
Chevy Camaro Forum
Toyota FJ Cruiser Forum
Ford Truck Forum
88-98 GM Truck Forum
73-87 Gm Truck Forum
Ford Expedition Forum
Chevy Equinox Forum
Chevy Cruze Forum
Jeep Liberty Forum
Jeep Forum
Dodge Ram SRT10 Forum
Chrysler 200 Forum
Scion xD Forum
Scion xB Forum
Dodge Challenger Forum
SRT Forum
Nissan Titan Forum
Buick Enclave Forum
Cadillac Forum
Cadillac XTS Forum
